Community Member
standalone ap with dhcp problem
I have an standalone ap but it is not work on the dhcp for wireless connection with the below config, but when i plug in the ethernet cable to the that is able to get the ip address, i have try to config related ip to do.1 or f0.1 or bvi1 but still not working.
Is it not possible to have a dhcp function on standalone ap?
ap_test#sh run
Building configuration...
Current configuration : 3015 bytes
version 12.4
no service pad
service password-encryption
hostname ap_test
logging rate-limit console 9
enable secret 5 $1$oJyM$DPgTtPIB82lhgm2bUP9b90
no aaa new-model
no ip dhcp use vrf connected
no ip dhcp conflict logging
ip dhcp excluded-address 10.18.20.1 10.18.20.200
ip dhcp excluded-address 10.18.20.203 10.18.20.254
ip dhcp excluded-address 192.168.0.1 192.168.0.200
ip dhcp excluded-address 192.168.0.203 192.168.0.254
ip dhcp pool wifi_test1
   network 10.18.20.0 255.255.255.0
   default-router 10.18.20.1
   dns-server 8.8.8.8
   lease 20
ip dhcp pool wifi_test2
   network 192.168.0.0 255.255.255.0
   default-router 192.168.0.1
   dns-server 8.8.8.8
   lease 20
dot11 syslog
dot11 ssid wifi_test1
   vlan 1
   authentication open
   authentication key-management wpa version 2
   mbssid guest-mode
   wpa-psk ascii 7 0217154A1A171E305D
dot11 ssid wifi_test2
   vlan 2
   authentication open
   mbssid guest-mode
   wpa-psk ascii 7 044A1A171E305D5F18
username Cisco password 7 05280F1C2243
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 1 mode ciphers aes-ccm tkip
encryption vlan 2 mode ciphers aes-ccm tkip
ssid wifi_test1
ssid wifi_test2
mbssid
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.2
encapsulation dot1Q 2
no ip route-cache
bridge-group 2
bridge-group 2 subscriber-loop-control
bridge-group 2 block-unknown-source
no bridge-group 2 source-learning
no bridge-group 2 unicast-flooding
bridge-group 2 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
dfs band 3 block
channel dfs
station-role root access-point
bridge-group 1
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
interface FastEthernet0.1
ip address 10.18.20.189 255.255.255.0
no ip route-cache
bridge-group 1
interface FastEthernet0.2
ip address 192.168.0.189 255.255.255.0
no ip route-cache
bridge-group 2
interface BVI1
no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
login local
end
ap_test#
Re: standalone ap with dhcp problem
You want the ap to be the dhcp server? Yes this can work.
So you don't need to IP address under the fastethernet subinterfaces. You just need to have the switchport configured as a trunk and at L3 put an ip helper pointing at the address of the AP.
Steve
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
Community Member
Hi stephen,
During the test, i got two SSID but i am not able to get the ip address through wireless but when i plug a computer to the ethernet port the ap it can get the ip address. Is there anything i miss in the configuration.
I find that this ap is set as
#station-role root
I find that some of the suggest is config tas non-root bridge but i it don't have this option, is it the way cause the dhcp fail?
ap_test(config-if)#station-role ?
  repeater          Repeater access point
  root              Root access point or bridge
  scanner           Scanner access point
  workgroup-bridge  Workgroup Bridge
221
