Supported aps for WLC 5500
What are the available APs that supports WLC5500?
Hall of Fame Super Gold
VIP Purple
Hall of Fame Super Silver
Re: Supported aps for WLC 5500
Just to add, it's the WLC code version that determines the support for access points not really the WLC model. This is because depending on what code you have on the 5508, the 5508 can support the 1600's only if on v7.4.x. If you had v7.0.x, then the 1600's would not be supported. So take a look at the matrix that Sandeep posted and also reference the guides for code version and the ap release notes which will tell you what code the WLC will also need to be on.
-Scott
113
