Supported WLAN controller and others
We have the following AP models  :
AIR-CAP1552EU-E-K9 (outdoor access point),
AIR-CAP-3602E-E-K9 ,
AIR-CAP-1602I-K9 ,
AIR-AP1252AG-E-K9
1. Can anyone suggest a Wireless LAN controller that would go with all of these APs ?
2. How can I know if the image on these APs is Autonomous or Light weight?
3. Any ideas into mounting the 1552 outdoor model AP ; and providing power source.
4. Is mesh configuration supported on all these APs ?
Thanks.
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
2504, 5508, WiSM-2, 8510,
2504, 5508, WiSM-2, 8510, vWLC, etc. can support these APs.  Older WLC, such as the 2000, 2100, 440X and WiSM-1 will NOT support 1550 but can support the rest.
Only the 1250 is autonomous.  If your AP model starts with "CAP" it means controller-based IOS.  Converting an autonomous AP to controller-based IOS is easy.  Just copy the RCV file into the AP and boot the IOS.
Thank you Leo. I will need to
Thank you Leo.
I will need to lookup how i can convert 1252 to controller-based.
Any directions to mesh configuration? I m not sure I m getting the concept right.
Also when I looked for WLC IOS support for below , its quite confusing if they will all work with 2505,5508,etc.
Table 1 Cisco WLC Software Releases, AP IOS Releases, and Supported Access Points
Cisco WLC Release
Access Point IOS Release
8.0.100.0
15.3(3)JAB /12.4(25e)JAP
Lightweight APs: 1040, 1130, 1140, 1240, 1250, 1260, 1600, 1702, 2600, 2700, 3500e, 3500i, 3500p, 3600e, 3600i, 3600p, 3702e, 3702i, 3702p, 600 OEAP, 700, 700W, AP801, and AP802
Outdoor Mesh APs: 1522, 1524PS, 1524SB, 1532E, 1532I, 1552E, 1552H, 1552I, 1552C, 1552EU, 1552CU, and 1552S
I mean what version will I get with the WLC by default?
VIP Purple
Hi,When you ask for quotation
When you ask for quotation from supplier then you can tell which version you want on WLC.
As leo said:
2504/5508/WiSM-2/8510/vWLC Can support all AP.
2100/wism1/400 can only support 1252,3602E,1552EU.
How to convert 1252 AP to Lightweight mode:
1. Download image from here:http://software.cisco.com/download/release.html?mdfid=281235915&flowid=6779&softwareid=280775090&release=15.2.4-JB6&relind=AVAILABLE&rellifecycle=ED&reltype=latest
2. Put in TFTP root directory
3. Login to AP and use this post for right command:
http://rscciew.wordpress.com/2014/05/07/access-point-conversion-lap-to-aap-and-vice-versa/
Dont forget to rate helpful posts
Thank you too!
It doesn't matter what software/firmware version you get your WLC.  The main thing is you get the WLC and you download the software/firmware upgrades from the Cisco website and upgrade the firmware yourself.
The software/firmware can be upgraded using GUI.
98
