switchport setup for lwapp access point running several ssid's
Hi all
when setting up an lwapp acces point, do I need to trunk all the vlans on the port to the ap? or do I only need to enable the management vlan to the acces point ? ie 1 vlan and normal access port ?
cheers
Carl
1 ACCEPTED SOLUTION
Re: switchport setup for lwapp access point running several ssid
If its a LWAPP AP, then the switchport should be a ACCESS PORT.. this is just to get the IP address to the AP, then the AP wil try to join the WLC.. once the AP joins, the SSID and rest flow through the LWAPP tunnel..
Surendra
Surendra
Unless you are doing HREAP with more then 1 SSID. Then it would be a trunk ...
__________________________________________________________________________________________ "Satisfaction does not come from knowing the solution, it comes from knowing why." - Rosalind Franklin ___________________________________________________________
587
