TCP/UDP ports between Cisco PI 2.0 and WLC5508
I will install Cisco PI 2.0 behind a firewall for security reason. The WLC5508 is before a firewall. Can anybody let me know which TCP/UDP ports need to be open specifically between the Cisco PI and WLC? I don't see that from the below link.
Cisco Prime Infrastructure 2.0 Quick Start Guide
http://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/2-0/quickstart/guide/cpi_qsg.html#wp46865
Robert
VIP Purple
Re: TCP/UDP ports between Cisco PI 2.0 and WLC5508
HI Robert,
If the Controller is behind a firewall, make sure that the UDP ports 161 and 162, which are used for SNMP communication between PI and WLC, are opened.
PI cannot communicate with WLC if it is behind a NAT device. This is not a supported configuration. The PI server needs direct IP connectivity to the controller.
Dont forget to rate helpful posts
VIP Purple
Firewall Between the WCS and Controller or WCS and the WCS User Interface
When a PI server and a PI user interface are on different sides of a firewall, they cannot communicate unless these ports on the firewall are open to two-way traffic:
  • 80 (for initial http)
  • 69 (tftp)
  • 162 (trap port)
  • 443 (https)
Open these ports in order to configure your firewall to allow communications between a PI server and a PI user interface.
89
