transmitter power error on 1600 series
Hi all,
I have a problem with 3 APs witch have a "transmitter power status as "error". The clients who want to connect have a realy weak signal.
i tried to up the gain of the dot11radio 0 but nothing change..
I have not externals antenna.
show int dot11radio 0 :
CSP-AP02-1er#sh int dot11Radio 0
Dot11Radio0 is up, line protocol is up
  Hardware is 802.11N 2.4GHz Radio, address is 2c3e.cf72.ccf0 (bia 2c3e.cf72.ccf0)
  MTU 1500 bytes, BW 54000 Kbit/sec, DLY 1000 usec,
     reliability 255/255, txload 255/255, rxload 1/255
  Keepalive set (10 sec)
  Last input 00:00:07, output 00:00:00, output hang never
  Input queue: 0/9355/0/0 (size/max/drops/flushes); Total output drops: 160
  Queueing strategy: fifo
  Output queue: 0/30 (size/max)
  5 minute input rate 11000 bits/sec, 7 packets/sec
  5 minute output rate 6000 bits/sec, 5 packets/sec
     493051 packets input, 89738870 bytes, 0 no buffer
     Received 3416 broadcasts (0 IP multicasts)
     118626 packets output, 44925181 bytes, 0 underruns
     13 output errors, 0 collisions, 7 interface resets
     0 unknown protocol drops
     0 lost carrier, 0 no carrier
shiow run :
interface Dot11Radio0
 no ip address
 no ip route-cache
 encryption mode ciphers aes-ccm tkip
 ssid MySSID
 antenna gain 2
 stbc
 beamform ofdm
 station-role root
 bridge-group 1
 bridge-group 1 subscriber-loop-control
 bridge-group 1 spanning-disabled
 bridge-group 1 block-unknown-source
 no bridge-group 1 source-learning
 no bridge-group 1 unicast-flooding
this is a screen with the error :
and a second one witch show that all trafic is going at 1mbps (the lowest rate) :
Can someone help me ?
Everyone's tags (1)
1 ACCEPTED SOLUTION
Please follow the below
Please follow the below discussion on same topic
https://supportforums.cisco.com/document/50526/how-configure-and-verify-transmitted-power-level-aps
Thank's for the tutorial but
Thank's for the tutorial but theses APs make 802.11n not b or g. What about that ?
133
