troubleshooting wireless issues 1100 series
one section of our warehouse is having some wireless issues.  wireless barcode scanners are locking up.  looking on the two APs in that area (both are 1100 series) I see some errors such as:
Interface Dot11Radio0, Deauthenticating Station  Reason: Previous authentication no longer valid
and
Packet to client  reached max retries, removing the client
I am trying to do some debuggin on the APs, but not seeing anything.
  1. I signon to the APs with hyperterminal, using my username and password.  returns what appers to be the mac address followed by # sign
  2. I type in "enable", nothing happens
  3. I type in 3 debugs:
    1. debug radius authentication
    2. debug dot11 aaa authenticator process
    3. debug dot11 aaa authenticator state-machine
but I never see any messages after that.
here is what I see on the current AP:
_________________________
001b2ac01820#enable
001b2ac01820#debug dot11 aaa authenticator process
process debugging is on
001b2ac01820#debug radius authentication
Radius protocol debugging is on
Radius protocol brief debugging is off
Radius protocol verbose debugging is off
Radius packet hex dump debugging is off
Radius packet protocol debugging is on
Radius elog debugging debugging is off
Radius packet retransmission debugging is off
Radius server fail-over debugging is off
001b2ac01820#debug dot11 aaa authenticator state-machine
state machine debugging is on
001b2ac01820#
________________________________
what am I doing wrong?
1 ACCEPTED SOLUTION
Channel 1 = 2412
Channel 6 = 2437
Channel 11 = 2462
From the carrier busy test, it looks like those channels are pretty busy in your area.  You might want to move the AP on channel 1 to 11.  6 is pretty busy as well, but it's better than 1.
HTH,
Steve
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
Take a look at the following link.  It goes over debugging on an IOS AP.
http://www.my80211.com/home/2011/12/15/basic-cisco-ap-debugging-autonomous-ios.html
But to speak to the errors you are seeing:
Packet to client  reached max retries, removing the client - the AP has sent a packet to the WLC 16 times, unless you have increased the max packet retries.  Once this happens, the AP assumes the client has moved away from it's service area and removes the client from the bridging table.
HTH,
Steve
got it.  thanks.
one more question, I got the carrier busy test to run via web browser, but have no idea how to read it.
the two access points in this area should be on channel 1 and then 6, so how doest that correlate to the frequency listed below?
Carrier                                  Busy Test Output
FrequencyCarrier Busy %
241261
241752
242261
242769
243260
243756
244250
244747
245257
245745
246246
Channel 1 = 2412
Channel 6 = 2437
Channel 11 = 2462
HTH,
Steve
cool.
many thanks steve.
one more question and I will leave you alone
all of our access points are either on channel 1, 6, or 11.  so why do I see the other frequency\channels listed on the carrier busy?
other equipment like microwaves or handheld phones?  or just bleedover?
In the 2.4GHz there are 11 usable channels.  But each channel is around 5MHz apart.  Now, let's take channel 6, as a good example here.
Channel 6's center point is 2437, but the channel is 20MHz wide.  So it covers from 2427 - 2447.  Any device on channel 6 will cause some interferrence with channels 4,5,7 and 8.
So in the 2.4GHz we only use 1,6,11 as they are the only channels that do not overlap with each other, and don't interferre with each other.
HTH,
Steve
got it. thanks.
learned something today.  never a bad thing.
348
