Two STAs do not see SSID, but others do.
Hello guys,
I was testing the flexconnect 802.1X, and noticed that one of my test laptops cannot see the SSID I created; however, all other laptops do see the SSID.
The laptops that were unable to see the flexconnect SSID are Dell E6410 and a virtual machine Windows 7 with wireless card, and the others that are able to see the SSID are Mabook Pro and Dell E6410.
In addition, these STAs that are not able to find my SSID are able to see others' SSIDs, but not mine. The APs that I am using are 3602i and the WLC is 5508.
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: Two STAs do not see SSID, but others do.
Since other devices have no issues, it's something most likely on the client side. Have you tried updating the drivers and removing the wireless profile from
The device and adding it back on manually? Apple devices like iPhones are the worst when it comes to not seeing an ssid, so if these devices can see the ssid, then the laptops that can't are most likely the issue here. If you have a lot of SSID's or if there are a lot if SSID's in the area, that can cause this behavior to with certain devices. Not much you can do if you have a lot of neighboring SSID's. One thing to try is to clear out the devices wireless profiles as maybe the list is too long.
-Scott
Hall of Fame Super Gold
The SSID is being broadcasted on ALL radios?
Just to add to Leo's post, post your show WLAN
-Scott
Yes, the broadcast SSID is enabled.
This is the show wlan 18
[code]
WLAN Identifier.................................. 18
Profile Name..................................... AAENG.FLEXCONNECT-INTERNAL
Network Name (SSID).............................. AAENG-FLEX-INTERNAL
Status........................................... Enabled
MAC Filtering.................................... Disabled
Broadcast SSID................................... Enabled
AAA Policy Override.............................. Enabled
Network Admission Control
Client Profiling Status
    Radius Profiling ............................ Enabled
     DHCP ....................................... Enabled
     HTTP ....................................... Disabled
    Local Profiling ............................. Disabled
     DHCP ....................................... Disabled
  Radius-NAC State............................... Enabled
  SNMP-NAC State................................. Disabled
  Quarantine VLAN................................ 0
Maximum number of Associated Clients............. 0
Maximum number of Clients per AP Radio........... 200
--More-- or (q)uit
Number of Active Clients......................... 0
Exclusionlist Timeout............................ 60 seconds
Session Timeout.................................. 1800 seconds
User Idle Timeout................................ Disabled
Sleep Client..................................... disable
Sleep Client Timeout............................. 12 hours
User Idle Threshold.............................. 0 Bytes
NAS-identifier................................... RK3W5508-01
CHD per WLAN..................................... Enabled
Webauth DHCP exclusion........................... Disabled
Interface........................................ management
Multicast Interface.............................. Not Configured
WLAN IPv4 ACL.................................... unconfigured
WLAN IPv6 ACL.................................... unconfigured
WLAN Layer2 ACL.................................. unconfigured
mDNS Status...................................... Disabled
mDNS Profile Name................................ unconfigured
DHCP Server...................................... Default
DHCP Address Assignment Required................. Enabled
Static IP client tunneling....................... Disabled
PMIPv6 Mobility Type............................. none
    PMIPv6 MAG Profile........................... Unconfigured
    PMIPv6 Default Realm......................... Unconfigured
--More-- or (q)uit
    PMIPv6 NAI Type.............................. Hexadecimal
Quality of Service............................... Silver
Per-SSID Rate Limits............................. Upstream      Downstream
Average Data Rate................................   0             0
Average Realtime Data Rate.......................   0             0
Burst Data Rate..................................   0             0
Burst Realtime Data Rate.........................   0             0
Per-Client Rate Limits........................... Upstream      Downstream
Average Data Rate................................ 128           128
Burst Data Rate.................................. 256           256
Scan Defer Priority.............................. 4,5,6
Scan Defer Time.................................. 100 milliseconds
WMM.............................................. Allowed
WMM UAPSD Compliant Client Support............... Disabled
Media Stream Multicast-direct.................... Disabled
CCX - AironetIe Support.......................... Enabled
CCX - Gratuitous ProbeResponse (GPR)............. Disabled
CCX - Diagnostics Channel Capability............. Disabled
Dot11-Phone Mode (7920).......................... Disabled
Wired Protocol................................... None
Passive Client Feature........................... Disabled
--More-- or (q)uit
Peer-to-Peer Blocking Action..................... Disabled
Radio Policy..................................... All
DTIM period for 802.11a radio.................... 1
DTIM period for 802.11b radio.................... 1
Radius Servers
   Authentication................................ 172.27.3.10 1812
   Accounting.................................... 172.27.3.10 1813
      Interim Update............................. Disabled
      Framed IPv6 Acct AVP ...................... Prefix
   Dynamic Interface............................. Disabled
   Dynamic Interface Priority.................... wlan
Local EAP Authentication......................... Disabled
Security
   802.11 Authentication:........................ Open System
   FT Support.................................... Disabled
   Static WEP Keys............................... Disabled
   802.1X........................................ Disabled
   Wi-Fi Protected Access (WPA/WPA2)............. Enabled
      WPA (SSN IE)............................... Disabled
      WPA2 (RSN IE).............................. Enabled
         TKIP Cipher............................. Disabled
         AES Cipher.............................. Enabled
--More-- or (q)uit
      Auth Key Management
         802.1x.................................. Enabled
         PSK..................................... Disabled
         CCKM.................................... Disabled
         FT-1X(802.11r).......................... Disabled
         FT-PSK(802.11r)......................... Disabled
         PMF-1X(802.11w)......................... Disabled
         PMF-PSK(802.11w)........................ Disabled
      FT Reassociation Timeout................... 20
      FT Over-The-DS mode........................ Enabled
      GTK Randomization.......................... Disabled
      SKC Cache Support.......................... Disabled
      CCKM TSF Tolerance......................... 1000
   WAPI.......................................... Disabled
   Wi-Fi Direct policy configured................ Disabled
   EAP-Passthrough............................... Disabled
   CKIP ......................................... Disabled
   Web Based Authentication...................... Disabled
   Web-Passthrough............................... Disabled
   Conditional Web Redirect...................... Disabled
   Splash-Page Web Redirect...................... Disabled
   Auto Anchor................................... Disabled
   FlexConnect Local Switching................... Enabled
--More-- or (q)uit
   flexconnect Central Dhcp Flag................. Disabled
   flexconnect nat-pat Flag...................... Disabled
   flexconnect Dns Override Flag................. Disabled
   flexconnect PPPoE pass-through................ Disabled
   flexconnect local-switching IP-source-guar.... Disabled
   FlexConnect Vlan based Central Switching ..... Disabled
   FlexConnect Local Authentication.............. Disabled
   FlexConnect Learn IP Address.................. Enabled
   Client MFP.................................... Optional
   PMF........................................... Disabled
   PMF Association Comeback Time................. 1
   PMF SA Query RetryTimeout..................... 200
   Tkip MIC Countermeasure Hold-down Timer....... 60
AVC Visibilty.................................... Disabled
AVC Profile Name................................. None
Flow Monitor Name................................ None
Split Tunnel (Printers).......................... Disabled
Call Snooping.................................... Disabled
Roamed Call Re-Anchor Policy..................... Disabled
SIP CAC Fail Send-486-Busy Policy................ Enabled
SIP CAC Fail Send Dis-Association Policy......... Disabled
KTS based CAC Policy............................. Disabled
Assisted Roaming Prediction Optimization......... Disabled
--More-- or (q)uit
802.11k Neighbor List............................ Disabled
802.11k Neighbor List Dual Band.................. Disabled
Band Select...................................... Disabled
Load Balancing................................... Disabled
Multicast Buffer................................. Disabled
Mobility Anchor List
WLAN ID     IP Address            Status
802.11u........................................ Disabled
MSAP Services.................................. Disabled
Local Policy
Priority  Policy Name
[/code]
-Scott
I tried reinstalling the drivers, but the laptop is rejecting it. And Windows keep installing the mini driver.
Yeah... I would maybe look for other drivers and it can be one or two versions older and see if those work. I usually recommend getting the driver from the devices manufacture site and not from the wireless card manufacture site. Some drivers might not be supported by the device manufacture.
-Scott
269
