04-02-2014 10:37 AM - edited 07-05-2021 12:36 AM
When I added to AP to the WLC i checked AP Mode Bridge. I recieve the following error message "Please change the 80211a channel and TxPower assignment method from GLOBAL to CUSTOMwireless->Access points->Radios->802.11a/n->Configure" I am able to make the change on slot 1 but not slot 2. I recieve the following message when I try to make these changes on slot 2. "Error in setting Channel Number Configuration. Error in setting TxPower Level Configuration" I'm not sure what I'm doing wrong.
04-09-2014 06:29 PM
Having the same issue on 7.6.110.0.
AP's have previously been connected to controller in bridge mode, now cannot change from local to Bridge.
Slot 1 has been changed however slot 2 throws the error MSG.
These same AP's have been connected to a controller on 7.4 Code previously.
04-09-2014 08:30 PM
Looks to be an issue with the code, reverted back to older code and did not have the same issue.
04-09-2014 11:43 PM
Once the AP was converted to a Bridge in 7.2 I then upgraded the controller to 7.6.110.0 and the AP's were configured in Bridge mode without the issue.
