Unable to find configuration guide for 866VAE-W-E-K9
Trying to find a configuration guide for Cisco 866VAE-W-E-K9.
I am unable to configure the wireless interface.
On other config guides i can see that there is an WLAN-AP0 interface.
In my case i have only WLAN-GIGABITETHERNET0 interface that is the only wireless interface i have, so i am unable to get into the embedded AP configuration.
I was configuring BVI100 int with an ip address, in addition i was creating loopback interface with 1.1.1.1 2.2.2.2 for telnet.
Still stuck :(
1 ACCEPTED SOLUTION
Hey Antoni,please check out
Hey Antoni,
please check out attached document on site 230 \ 11-11.
"Connecting to WLAN CLI Interface"
You have to create a loopback Interface thats correct.
After that simply telnet to the Loopback Interface with port 2002.
You´re now connected to the internal access point !
Gold
Configuration Guide :The
The Cisco 866VAE, Cisco 867VAE, Cisco 866VAE-K9, and Cisco 867VAE-K9 routers can be configured to use either a GE interface or a DSL interface as a WAN link. DSL is the default WAN interface when the Cisco 866VAE, Cisco 867VAE, Cisco 866VAE-K9, and Cisco 867VAE-K9 routers boot.
After the router boots up, the desired WAN interface can be selected using the wan mode command. When WAN mode is configured as Ethernet, both ATM0 and Ethernet0 interfaces will be forced into shutdown state. Entering the no shutdown command on either of the DSL interfaces will be rejected with a message WAN interface is Ethernet . Similarly, when the WAN mode is DSL, the GE WAN interface will be put in shutdown state and the no shutdown command will be rejected with the message WAN interface is DSL .
http://www.cisco.com/c/en/us/td/docs/routers/access/800/860-880-890/software/configuration/guide/SCG880-860/routconf.html
Hi Mohanak,i do not have the
Hi Mohanak,
i do not have the interface WLAN-AP0.
I have only WLAN-GIGABITETHERNET0 (that is for wireless interface)
interface wlan-ap0
description Service Module interface to manage the embedded AP
ip unnumbered Vlan1
no cdp enable
arp timeout 0
How do i configure wireless on a 866vae-w-e-k9 ?
The document isn't referring to Cisco 866VAE-W-E-K9 but referring to Cisco 866VAE and Cisco 866VAE-K9.
http://www.cisco.com/c/en/us/products/collateral/routers/800-series-routers/data_sheet_c78-693249.html
Hi vattullu,The document is
Hi vattullu,
The document is only informative and not a configuration guide.
Thx.
bump.
bump.
Cisco has no docs on the internet regarding the C866vae-W series (at least regarding wireless configuration) shame.
are you still having trouble
are you still having trouble with this? Can you share what you see some ouputs?
show interfaces
show version
what happens when you try
    conf t
       interface wlan-ap0
NO WLAN-AP0 INTERFACE EXSIST
NO WLAN-AP0 INTERFACE EXSIST.
ONLY WLAN-GIGABITETHERNET0.
iOS version 15.3
AP(config)#int bvi ?  <1-255>
  <1-255>  BVI interface number
AP(config)#int bvi
Enter configuration commands, one per line.  End with CNTL/Z.
AP(config)#int bvi1
% Bridge group 1 is not configured
AP(config)#int wlan-ap0
% Invalid input detected at '^' marker.
AP(config)#sh ver
Cisco IOS Software, C860 Software (C860VAEW-ADVSECURITYK9-M), Version 15.3(3)M2, RELEASE SOFTWARE (fc1)
Hi Antoni, Did you ever find
Hi Antoni,
Did you ever find any relevant docs in regards to configruing the wireless for the 866VAE-W-E-K9 as I am in the same situation?
Hey Peng,How did you go? I
Hey Peng,
How did you go? I had a similar issue but worked my way around it.
also had this problem but
also had this problem but NOBODY mentioned that you are not able to connect via Telnet. you must be logged into the router via console otherwise you get a refused.
So like this ->
Like Jan-H.Sohn Said
I had to issue the following to get AP access.
(config)#interface loopback 0
(config-if)#ip address 1.1.1.1 255.255.255.255
#telnet 1.1.1.1 2002
default username/password is admin/admin but will prompt to change password. then use: ctr-shift-6...then x...then enter 'disconnect' to get out of AP.
But make sure you don't try this via Telnet / VTY alike ( ethernet port  / remote from network) etc but use console cable and Telnet  and you are able to get to the AP settings :)
Hree is the link to configure
Hree is the link to configure the 860 series wireless ISR :-
http://www.cisco.com/c/en/us/td/docs/routers/access/800/860-880-890/software/configuration/guide/SCG880-860/wlan.html
HI,like i said i do not have
HI,
like i said i do not have the interface wlan-ap0 at all.
Hey Antoni,
Thank's mate,finaly someone
Thank's mate,
finaly someone understand what I'm asking to know.
will try that this week and will post the status.
Nope :)the cisco guys also
Nope :)
the cisco guys also dont know the 866VAE-W-E-K9 in detail.
Don´t mind why the way to connect & configure is some kind of special on this specific device.
Thank you!!!Like Jan-H.Sohn
Thank you!!!
Is there a way also to
Is there a way also to completely disable the wlan (led off)? Cant find any material.
If you´re logged in into the
If you´re logged in into the integrated AP you can set the .1Radio Interface to shutdown.
4755
