Unable to join AIR-AP1231 to virtual WLC
We are trying to join an AIR-AP1231 to our new virtual WLC. (Software Version 7.4.100.0)
To upgrade the AP, we followed this guide:
http://www.cisco.com/en/US/docs/wireless/access_point/conversion/lwapp/upgrade/guide/lwapnote.html#wp176272
After the upgrade process the AP boot with this IOS -> flash:/c1200-rcvk9w8-mx.124-21a.JA2/c1200-rcvk9w8-mx.124-21a.JA
and then it show attached messages on CLI.
I read on that discussion : https://supportforums.cisco.com/thread/2170822
that first time could be needed a physical WLC. And the one who open the discussion solved installing last IOS.
Is there any other procedure that we can do to solve that problem if we haven't any other WLC and we are using last realeased IOS on the AP?
Thanks in advance
*Oct 17 16:16:42.001: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Oct 17 16:16:42.032: %LWAPP-3-CLIENTERRORLOG: Peer certificate verification failed
*Oct 17 16:16:42.033: %CAPWAP-3-ERRORLOG: Certificate verification failed!
*Oct 17 16:16:42.033: DTLS_CLIENT_ERROR: ../capwap/capwap_wtp_dtls.c:326 Certificate verified failed!
*Oct 17 16:16:42.033: %DTLS-4-BAD_CERT: Certificate verification failed. Peer IP: 10.20.20.60
*Oct 17 16:16:42.033: %DTLS-5-SEND_ALERT: Send FATAL : Bad certificate Alert to 10.20.20.60:5246
*Oct 17 16:16:42.034: %DTLS-3-BAD_RECORD: Erroneous record received from 10.20.20.60: Malformed Certificate
*Oct 17 16:16:42.034: %DTLS-5-SEND_ALERT: Send WARNING : Close notify Alert to 10.20.20.60:5246
*Oct 17 16:17:47.000: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Oct 17 16:17:57.012: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Oct 17 16:17:57.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.20.20.60 peer_port: 5246
VIP Purple
Re: Unable to join AIR-AP1231 to virtual WLC
1231 ap does not supported by anything higher than WLC code 7.x
291
