Unable to reach WISM2 management interface
I've just reset our WISM2 in the test lab back to factory default as I needed to reconfigure the 6500 and the WISM2 itself. Bearing in mind I had it working before.
I've just renamed and re-addressed some of the vlans so things flow better and make it easier to add more WISM2s in the future.
Now I've run through the initial configuration and it's rebooted ok and show WISM status is showing Oper-Up and there's a port channel 407 been created as I would expect. However, I am unable to get to the management interface via GUI or SSH. In fact from the 6500 I can't even ping the management interface (but I can the service port).
The Vlans have been changed in the 6500 config so it knows the native-vlan and service vlan etc and all the vlans are up/up.
Any ideas? I've re-addressed the virtual interface in case it was that. I know it worked before, it's only after the vlan changes that I've had this.
1 ACCEPTED SOLUTION
Re: Unable to reach WISM2 management interface
ok, the reason you can't reach the WiSM is you are tagging on the WLC and the switch side.  With a dot1q trunk, if it sees it's own tag it will drop the traffic.  So there are two thins you can do:
1.) Set the management on the WLC to be VLAN 0 (untagged)
2.) Change the native vlan on the switch to an unused VLAN. <--preferred method.
What option 2 gives you, is any traffic that happens to get untagged will go no where.
Steve
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
I faced this issue yesterday after I rebooted WiSM, I could fine the port channel associated with the WiSM was in susupended state. I cleared the configurations for the WiSM port-channel, did the reboot of the WiSM using the hw-module reset command, when the WiSM came back up, i configured the port-channel and then rebooted the WiSM again. I could ping my WiSM after this
I'll go down and check in a few minutes but I thought the port-channel was automatically created by the 6500 detecting the module. I didn't think you could alter it in any way.
As I suspected I am unable to alter the configuration of the port channel in any way (as it's above 256). I can see that it doesn't have any configuration on it though. I have tried a hard reset of the WiSM2 (reseated the module) and it is still the same.
Wism module
Do you have these commands configured?
Steve
currently this is what I have for these commands, which worked before. The only difference is the vlan numbering. This is a WISM2 so only the single controller.
wism service-vlan 1504
wism module 4 controller 1 allowed-vlan 1006-4094
wism module 4 controller 1 native-vlan 1501
wism module 4 controller 1 qos trust dscp
What i did was this for my issue
I removed this configuration, reseted the wism using the "hw-module reset" command then configured the commands
and then resetted the wism again
I have just performed this function and unfortunately I am still unable to access the management interface. I know it's going to be something simple.
I agree it is not gonna be simple,
I tried more than an hour, with various combinations of the step I mentioned to get it working
Just a stupid question over here, Hope no one would have changed the gateway IP and vlan
It's just me working in the lab, so I doubt it. Like I said, I have just changed all the vlans and that's seems to have upset it somewhat. I'll keep trying, but it's frustrating when everything on the controller and the 6500 seem to indicate everything is fine.
Can you session in and post the output from show interface summary ?
Steve
Here you go
(WiSM-slot4-1) >show interface summary
Interface Name                   Port Vlan Id  IP Address      Type    Ap Mgr Guest
management                       LAG  1501      10.15.101.1     Static  Yes    No
service-port                         N/A    N/A       10.15.104.1     Static  No     No
virtual                                 N/A    N/A        1.1.1.1           Static  No     No
Steve
DOH! That was it. I've been doing this from memory and I guess I forgot the basics. It's reachable now. Thanks a lot people.
Hey you have configured the native vlan for the port channel and configured the same vlan for the management interface. Make your management interface untagged,
Wonder how it worked before for you
We experienced the same problem of not being able to connect to a WiSM2 that was properly configured to receive UNTAGGED traffic.
The problem was this other global command:
     vlan dot1q tag native
We had to do a 'no vlan dot1q tag native' to gain access to our WiSM2.
Why is everyone using native and not tagging all your traffic ? You aren't trusting the native traffic when you use mls aps trust cos on the trunks into the wlc. Also the config guide is specific in 7.x to tag all traffic ..
__________________________________________________________________________________________ "Satisfaction does not come from knowing the solution, it comes from knowing why." - Rosalind Franklin ___________________________________________________________
2280
