Upgrade Tool Problems
I’m having problems using the Upgrade tool, using the internal TFTP server try as I might I can’t persuade that there isn’t a firewall or ACL blocking TFTP:
-          I’ve tried using v3.2 and v3.4
-          I’ve tried using different machines
-          I’ve turned off all firewalls and removed all ACLs from the APs
-          I’ve traced the route across the network and can’t see any reason why any traffic would be blocked between the two
-          I can confirm from the TACACS server that the upgrade tool is authenticating
Using the external TFTP Server I can’t persuade it to work as there seems to be a fault in the script that the upgrade tool tries to run, I’ve looked throught the log the important bit seems to be below where it tries to answer exit to a yes/no question:
KCHCam.Gnd.Ap1130.4(config)#crypto ca enroll CISCO_IOS_SSC_Cert
The router has already generated a Self Signed Certificate for
trustpoint TP-self-signed-3298014188.
If you continue the existing trustpoint and Self Signed Certificate
will be deleted.
Do you want to continue generating a new Self Signed Certificate? [yes/no]: yes
% The fully-qualified domain name will not be included in the certificate
Generate Self Signed Router Certificate? [yes/no]: exit
% Please answer 'yes' or 'no'.
Generate Self Signed Router Certificate? [yes/no]:  test ssc enable
Generate Self Signed Router Certificate? [yes/no]: show crypto ca certificates
The failure message is below:
2010/08/10 11:17:50 ERROR       172.16.130.154  Unable to Get Root Certificate Status
Any help would be greatly appreciated.
Chris
1 REPLY
Re: Upgrade Tool Problems
Have you try remove domain configuration on your autonomous ap? or just write erase and try again.
768
