urgent :same SSID in 4 AP 1240
help,
I'm planning on implementing 4 AP's autonomous in my company.I use one ssid, and the possibility
to roam between access points without loosing connection.but
I can see only SSID distributed by AP (A and C)
i move near of AP (B and D) but I think that SSID is hidden
because i find the singal with "Network Stumbler"
*Config:
A and C:802.11g=ROOT and 802.11a=root bridge
B and D:802.11g=ROOT and 802.11a=non-root bridge
this is my config for A and B
what is the probleme in my config?
reply please.
Re: urgent :same SSID in 4 AP 1240
Taken from config-B.txt
interface Dot11Radio0
ssid palace wifi
station-role root
Change access point B from root to non-root.
HTH>
hi thanks for your reply,
ok I am going to test it and I go you aware.
at the time of analysis of the frequencies I found some ap that work
with the same frequency that my APs
I could solve the problem by change of the frequencies thank you for your help
Blue
Youssef:
I have a question:
If you are only using one SSID, why do you have 2 of them configured on the AP, one under the dot0 and the other under dot1 interface?
Also, you are right, you should use non-overlapping frequencies when the APs are next to each other. Typically, in dot11.b/g radios, frequencies 1, 6 and 12 are used because they do not overlap.
Victor
hi
I use 2 SSID one under dot0 for 802.11b/g
and the other under dot1 for 802.11a
(link point to point between AP A and B)
because i don't have the wired DS therefore I use DS wireless
thanks
206
