Community Member
Users are being disconnected after a few minutes of connecting to the wireless on a 1042N AP.
#Sh run and #show tech have been taken from the AP.
Time out on the AP has been increased from 3600 to 36000.
#dot11 activity-timeout client default 36000
Following messages still appearing:
028965: Mar  4 15:56:55.505 Mexico: DOT11-6-ASSOC Interface Dot11Radio0,
Station   5c0a.5bc5.c651 Associated KEY_MGMT[WPAv2 PSK]
028966: Mar  4 15:58:29.344 Mexico: DOT11-6-DISASSOC Interface
Dot11Radio0, Deauthenticating Station 00e6.6648.e0e8 Reason: Sending station
has left the BSS
028967: Mar  4 15:58:29.446 Mexico: DOT11-6-ASSOC Interface Dot11Radio0,
Station   00e6.6648.e0e8 Associated KEY_MGMT[WPAv2 PSK]
028968: Mar  4 15:58:30.325 Mexico: DOT11-6-DISASSOC Interface
Dot11Radio0, Deauthenticating Station 0870.4553.77da Reason: Sending station
has left the BSS
028969: Mar  4 15:58:30.346 Mexico: DOT11-6-ASSOC Interface Dot11Radio0,
Station   0870.4553.77da Associated KEY_MGMT[WPAv2 PSK]
028970: Mar  4 15:58:36.809 Mexico: DOT11-6-DISASSOC Interface
The following commands have been added to the AP:
#rts threshold 512
#rts retries 128
Channel used seems clear:
#show dot11 carrier busy
Frequency  Carrier Busy %
   2412         20
   2417         18
   2422         19
   2427         17
   2432         25
   2437         46
   2442         14
   2447         82
   2452         92
   2457         88
   2462         85
interface Dot11Radio0
no ip address
ip accounting output-packets
no ip route-cache
encryption mode ciphers aes-ccm
ssid Avenger
antenna gain 0
packet retries 128 drop-packet
channel 2432
station-role root
rts threshold 512
rts retries 128
Any suggestion?
Hall of Fame Super Blue
Wow. That's one busy radio
Wow. That's one busy radio band. Can you elaborate if the clients having these issues are connected to 802.11b or 802.11a radio? Would you also be able to provide what data rates are enabled? Judging from the carrier test output, it looks like you've got a very strong co-channel interference issue.
Community Member
Leo,The rates on the AP are
Leo,
The rates on the AP are deafult, so no rates are shown on the #sh run.
Ok.  Can you disable 1, 2, 5
Ok.  Can you disable 1, 2, 5 and 11 Mbps data rates?  Make 18 as Mandatory and 12 and the rest as Supported?
Hall of Fame Super Silver
channel 2432Channel 5????  I
channel 2432
Channel 5????  I would change that to channel 1, 6 or 11... channel 1 looks the best.
-Scott
Community Member
Hi Scott,Thank you for that
Hi Scott,
Thank you for that observation, I will move it to channel 1 and see how it behaves.
123
