Using 3560 8 port PoE to power up 1252 dual radio AP for b\g clients
mo shea
We have a couple of 3560 8 port PoE switches that we plan to use to power up 1252 APs (not ordered yet). Now since the 3560 switch will only support one radio, is it possible to order a pre installed dual radio 1252 AP, disable the 5 Ghz one and enable the 2.4 Ghz, so that b/g clients can access the network, until a PoE+ switch is purchased?
All help is appreciated
Correct.  As standard G/A rates only require one tx/rx, there is no degradation in service.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
mo shea
Just to clarify my question, since this 3560 switch can supply power enough for only one radio, and if I choose to disable the 5Ghz one and keep the 2.4 Ghz radio enabled, does this configuration support wireless laptops with 802.11n cards only or 802.11b/g/n.
Are there any drawbacks of such a setup.
Thanks again.
Slight misconception here.  The 3560 will power the AP and both radios, so long as you are running 4.2.112.0 or higher on the WLC, or 12.4(10b)JDC or higher for an autonomous AP.  The caveat here, is you will run in a degraded state for N rates.
The below link describes the power to N rate relationship:
http://www.cisco.com/en/US/docs/wireless/controller/release/notes/crn421120.html#wp366903
HTH,
Steve
Thanks Stephen for the explanation.
Since I would be using autonomous APs, if the ios version is older than the one you mentioned, I would still be able to connect b/g/n clients using the 2.4 radio with no performance degradation. Right?
Thanks again
HTH,
Steve
