Using AP 1310 as repetears - dropping randomly
I am doing remote support for RV park and we have following setup: Gateway-->WAP(root)--> three wireless backhauled repeater AP's back to the root. Pretty simple setup. All Cisco 13010. We're having issues with repeaters dropping randomly and some users not being able to connect to those AP's.All of repeaters have one antenna on them. Repeaters are about 250ft from each other and from the root AP. We have one SSID for clients and one for AP's to communicate with eachother.
What would be proper way to configure this kind of deployment? I am providing current config for the root AP and for two repeaters. Just looking at the config, are we doing something wrong here?
As you can see from AP2 config we even tried to statically assign parent to it.
Thanks in advance
AP1 ROOT
Building configuration...
Current configuration : 2432 bytes
version 12.3
no service pad
service password-encryption
hostname AP1
no logging console
enable secret 5 #############
ip subnet-zero
no ip domain lookup
aaa new-model
aaa group server radius rad_eap
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
aaa group server tacacs+ tac_admin
aaa group server radius rad_pmip
aaa group server radius dummy
aaa authentication login default local
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authorization exec default local
aaa accounting network acct_methods start-stop group rad_acct
aaa session-id common
dot11 ssid TEST
   authentication open
   guest-mode
dot11 ssid wireless_backhaul
   authentication open
   infrastructure-ssid
username Cisco password 7 #####
username admin privilege 15 password 7 ######
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
ssid TEST
speed basic-1.0 2.0 5.5 6.0 9.0 11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root access-point
concatenation
mobile station period 20 threshold 70
antenna receive right
antenna transmit right
antenna gain 12
infrastructure-client
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
keepalive 100
bridge-group 1
hold-queue 80 in
interface BVI1
ip address 10.61.32.51 255.255.255.0
no ip route-cache
ip default-gateway 10.61.32.1
ip http server
ip http authentication aaa
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
logging trap warnings
logging facility local1
snmp-server community ####### RO
snmp-server community ####### RW
snmp-server enable traps tty
radius-server attribute 32 include-in-access-req format %h
radius-server vsa send accounting
control-plane
bridge 1 route ip
line con 0
line vty 0 4
password 7 #########
line vty 5 15
end
AP3 (repeater)
Current configuration : 2325 bytes
version 12.3
no service pad
hostname AP3
no logging console
enable secret 5 $1##################
ip subnet-zero
aaa new-model
aaa session-id ##########
dot11 ssid TEST
   authentication open
   guest-mode
   authentication open
   infrastructure-ssid
username Cisco password 7 #############
username admin privilege 15 password 7 ##################
bridge irb
no ip address
no ip route-cache
ssid TEST
station-role repeater
bridge-group 1
no ip address
no ip route-cache
keepalive 100
bridge-group 1
hold-queue 80 in
interface BVI1
ip address 10.61.32.53 255.255.255.0
no ip route-cache
no ip http server
snmp-server community ########### RO
snmp-server community ############## RW
control-plane
bridge 1 route ip
line con 0
line vty 0 4
line vty 5 15
end
WAP2 (repeater)
Current configuration : 2408 bytes
version 12.3
no service pad
hostname AP2
no logging console
enable secret 5 $1####################
ip subnet-zero
aaa new-model
dot11 ssid TEST
   authentication open
   guest-mode
   authentication open
   infrastructure-ssid
username admin privilege 15 password 7 060C450C61050E0054
bridge irb
no ip address
no ip route-cache
ssid TEST
parent 1 0024.9717.0de0
parent timeout 60
concatenation
antenna gain 12
bridge-group 1
no ip address
no ip route-cache
keepalive 100
bridge-group 1
hold-queue 80 in
interface BVI1
ip address 10.61.32.52 255.255.255.0
no ip route-cache
ip http server
snmp-server community ############# RO
snmp-server community ############# RW
control-plane
bridge 1 route ip
line con 0
line vty 0 4
line vty 5 15
end
Re: Using AP 1310 as repetears - dropping randomly
Maybe you could set the AP Mode of the (GW)  to RootBridge to (RootBridge w/ Wireless Clients) and the other AP/Bridge to (Non-RootBridge w/ Wireless Clients)
Thanks for your reply.
Will they still be able to talk back to the root AP in this configuration? Remember, everythign is wirless except AP1 (root) which is wired back to the gateway. I thought you can only set wireless AP's in repeater mode. But maybe I'm off here.
You can set the role-mode to Root Bridge w/ Wireless Clients and Non-root Bridge w/ wireless clients. The one connected to the LAN must be the Root while the other two will be Non-Root.
420
