Using Hyperterminal
I have a test WAP that is new in box. When I console in it goes through all of the initial settings including grabbing an IP address. However it just stops and doesn't give me a prompt to begin commands. I can telnet and web into the WAP but the Hyperterminal just sits there. Is there a key combo I'm missing?
1 ACCEPTED SOLUTION
Gold
Re: Using Hyperterminal
Make sure your terminal settings in hyperterm has flow control off.  If it is on in any fasion you'll see the output from the AP but it will not accept any keyboard input.
1 REPLY
Gold
183
