Using only one antenna on 1552EU
we had Cisco AIR-LAP1522 with three 2,4GHz antennas and one for 5GHz. A normal setup I would say. The access point malfunctioned a while ago and we got a replacement part after TAC case. Because of EoS, we received a AIR-CAP1552EU-E-K9 access point.
The idea was to use the same antennas, but when I try to configure a/n band to use only one connector (A, B or C) nothing happens. After clicking Apply, all check boxes are still active/enabled. Is there a reason for this? Is it possible to disable diversity?
WLC version is 7.4.110.0. and I'm using GUI to configure.
Hall of Fame Super Silver
Re: Using only one antenna on 1552EU
I don't think you can do that on the 1552e. You need to purchase the dual band antennas that are designed for that model and use all three. That is your best bet to get the performance and stability and possible TAC support on that device.
-Scott
Hi Scott,
the model is 1552EU. It has six single band antennas. We choose that one over 1552E, so we could use the old antennas.
Okay.. Well that does split the radios per antennas. I think you are still required to use the correct amount of antennas. I have not deployed mesh with trying to use existing antennas, because they also have been exposed a long time out in the environment. I have seen antennas go back after long use. If this is an issue, open a TAC case since they are new and confirm that you can't or can do what you want.
-Scott
217
