Ver 7.4 / Do we use the management I.P or Redundant I.P for LWAP?
I have a general question.
I've x-out some numbers for privacy reason.
On 7.3/7.4, I believe they share the same management I.P when SSO is enabled.
With that said, do the AP use that for the WLC or do they point to the Redundant Management I.P and use the Peer Management I.P as their secondary WLC?
Or should their only be one entry on the AP that points to the management I.P?
Hope that makes sense.
For example, our management is X.X.117.4 and our redundant is .5 and peer redundant is .9
How would the AP be setup in this case?
(Cisco Controller) >show redundancy summary
Redundancy Mode = SSO ENABLED
     Local State = ACTIVE
      Peer State = STANDBY HOT
            Unit = Primary
         Unit ID = XXXXXXXX
Redundancy State = AP SSO
    Mobility MAC = XXXXXXXX
Average Redundancy Peer    Reachability Latency = 526 usecs
Average Management Gateway Reachability Latency = 5916 usecs
Redundancy Management IP Address................. X.X.117.5
Peer Redundancy Management IP Address............ X.X.117.9
Redundancy Port IP Address....................... 169.254.117.5
Peer Redundancy Port IP Address.................. 169.254.117.9
Peer Service Port IP Address..................... 0.0.0.0
1 ACCEPTED SOLUTION
With AP SSO, you only need the management address of the WLC configured on the AP.  If the primary fails, the secondary takes up that address.
Think of it like HSRP, you use the standby address for your gw, not the individual one for the switch.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
Awesome! Thank you so much.
85
