Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Very frustrated. Another guest / corp lan config question
3 books, 100 hrs of CBT's and a certification and i STILL cant figure out how to set this up right.... i have it "running" with security and everything, but its just not done right. everything is running off the mgt interface.
ok, i work at a cardiovascular practice with 2 locations. what we have is a 2106 WLC and 5 1120(?) Ap's a router on a stick scenario.
our "Main" site uses 172.22.1.0/24 internally
"Site2" used 172.22.2.0/24
I pray someone can explain this to me.... heres what  i'd like to do:
at site 1:
create a guest lan using b/g/n 2.4 that our physicians etc can use that is internet only. (vlan 6 172.22.6.0 and would LOVE to have the WLC do the DHCP)
for this, would i have to change the mgt subnet to /16 instead of /24?
create an a/n 5.0 for our exam rooms and ECG etc equip that is on our internal Lan (No SSID broadcast)
now, i see that i need to create dynamic interfaces (ex: guest and  corp_wlan)... do i assign a vlan, ip's and port to each  interface?   then physically cable from that port to an open port on our switch? and  does that port selection mean i do not need to set up trunking on that  switch port?  i know i will need it on our router as a subinterface, but  thats not a big deal.
how do i add only the b/g/n 2.4 to a particular (guest) interface?
and the a/n 5.0 to the corp_wlan interface?
part 2 of this:
we have 2 locations and the AP's are running HREAP at location 2.  would  i have to have both vlans defined over there if they are connecting  back or would i be able to manage them (the AP's) from site 1 and use  the network at site 2 for their internet and server etc access so they dont have to cross back and use ours?
i hope this makes sense.
4 ACCEPTED SOLUTIONS
See my answers inline
at site 1:
Well, There is no need to change the management subnet if you need to degfine internal DHCP scope on the WLC.
Make sure that the DHCP proxy is enabled
and under the dynamic interface defined for vlan 6 , put the ip address of the manament interface of the WLC as the primary DHCP server.
There is no need to assign separate port for each interface, have them mapped to port one , connect it to neighbor switch , configure that switchport as trunk allowing all the VLANs needed.
You cannot assign the radio policy based on the interface but you can do it per WLAN.
When you define the WLAN , under the general TAB , Radio policy , you can select the policy needed either g only or a only.
part 2 of this:
You can enable HREAP local switching per WLAN , under the advanced tab .
When you do so the wlan traffic will be switched be locally at the remote site without the need to be tunneled back to the main controller. In that case you have to make sure that your AP is connected to trunk switch port to allow traffic for more than one wlan locally switched to be switched properly.
Please Don't Forget to rate correct answer
one problem i get when i try to enable the guest dhcp scope is "network conflicts with default router"
the network is 172.22.6.0/24 and default router (GW) is 172.22.1.240/24 should i reset that back to 0.0.0.0? or change the mask to /16?
THere is no need to change anything the two networks mentioned are completely separate and not overlapping at all.
next time i am in there, i will see where the WLC is wired in and change that port to a trunk on the switch.
after that, all i need to do is add the subinterface and same vlan id to my router and i should be ok on this part?
yes
Hello Tim
Sorry for the inconvenience . Whenever you define A DHCP scope representing certain vlan , the subnet id should be the same for the default router.
In your case you were trying with default router ip not in the same subnet.
The gateway should be something like 172.122.6.X/24
Please Don't forget to rate correct answer
yes it should be a subinterface added to your router on stick
Please Make sure to rate correct answer
at site 1:
part 2 of this:
thank you for your reply!  this may be possible afterall...
i enabled DHCP proxy and added the mgt interface and DHCP server.
yes
but im unable to enable the dhcp scope because of that error.
the mgt interface is 172.22.1.222
our default router (GW) is 172.22.1.240
the guest wlan is 172.22.6.2
the scope i would like to use is 172.22.6.100-200
please attach show run-config from the WLC
Sorry about this, but its 30+ pages long... is there a way to extract only the info we need?
Sorry if this is too large etc. i cant see where to attach a file.  i did my best, Putty made me scroll 5-6 pages at a time.
Switch Configuration
802.3x Flow Control Mode......................... Disable
FIPS prerequisite features....................... Disabled
secret obfuscation............................... Enabled
Press Enter to continue or to abort
Network Information
RF-Network Name............................. TCS
Web Mode.................................... Enable
Secure Web Mode............................. Enable
Secure Web Mode Cipher-Option High.......... Disable
Secure Web Mode Cipher-Option SSLv2......... Enable
Secure Shell (ssh).......................... Enable
Telnet...................................... Disable
Ethernet Multicast Forwarding............... Disable
Ethernet Broadcast Forwarding............... Disable
AP Multicast/Broadcast Mode................. Multicast   Address : 0.0.0.0
IGMP snooping............................... Disabled
IGMP timeout................................ 60 seconds
User Idle Timeout........................... 300 seconds
ARP Idle Timeout............................ 300 seconds
Cisco AP Default Master..................... Enabled
AP Join Priority............................ Disable
Mgmt Via Wireless Interface................. Disable
Mgmt Via Dynamic Interface.................. Enable
Bridge MAC filter Config.................... Enable
Bridge Security Mode........................ EAP
Mesh Full Sector DFS........................ Enable
--More or (q)uit current module or to abort
AP Fallback ................................ Enable
Web Auth Redirect Ports .................... 80
Fast SSID Change ........................... Disabled
IP/MAC Addr Binding Check .................. Enabled
Port Summary
           STP   Admin   Physical   Physical   Link   Link
Pr  Type   Stat   Mode     Mode      Status   Status  Trap     POE
1  Normal  Forw Enable  Auto       100 Full   Up     Enable  N/A
2  Normal  Disa Enable  Auto       Auto       Down   Enable  N/A
3  Normal  Disa Enable  Auto       Auto       Down   Enable  N/A
4  Normal  Disa Enable  Auto       Auto       Down   Enable  N/A
5  Normal  Disa Enable  Auto       Auto       Down   Enable  N/A
6  Normal  Disa Enable  10 Half    10 Half    Down   Enable  N/A
7  Normal  Disa Enable  Auto       Auto       Down   Enable  Enable  (Power Off)
8  Normal  Disa Enable  Auto       Auto       Down   Enable  Enable  (Power Off)
AP Summary
Number of APs.................................... 3
Global AP User Name.............................. Not Configured
Global AP Dot1x User Name........................ Not Configured
AP Name             Slots  AP Model             Ethernet MAC       Location          Port  Country  Priority
Hyannis_Flr2         2     AIR-LAP1142N-A-K9    1c:df:0f:b5:31:29   Conference Room  1     US       1
Hyannis_Flr1         2     AIR-LAP1142N-A-K9    00:07:7d:2d:7b:f8         Dr Office  1     US       1
Falmouth_AP          2     AIR-LAP1142N-A-K9    58:8d:09:37:c7:3e          Falmouth  1     US       1
AP Location
Site Name........................................ default-group
Site Description.................................
WLAN ID          Interface          Network Admission Control
1               management           Disabled
2               management           Disabled
3               tcs                  Disabled
AP Name             Slots  AP Model             Ethernet MAC       Location          Port  Country  Priority  GroupName
Hyannis_Flr2         2     AIR-LAP1142N-A-K9    1c:df:0f:b5:31:29   Conference Room  1     US       1         default-group
Hyannis_Flr1         2     AIR-LAP1142N-A-K9    00:07:7d:2d:7b:f8         Dr Office  1     US       1         default-group
Falmouth_AP          2     AIR-LAP1142N-A-K9    58:8d:09:37:c7:3e          Falmouth  1     US       1         default-group
AP Config
Cisco AP Identifier.............................. 1
Cisco AP Name.................................... Hyannis_Flr2
Country code..................................... US  - United States
Regulatory Domain allowed by Country............. 802.11bg:-A     802.11a:-A
AP Country code.................................. US  - United States
AP Regulatory Domain............................. -A
Switch Port Number .............................. 1
MAC Address...................................... 1c:df:0f:b5:31:29
IP Address Configuration......................... Static IP assigned
IP Address....................................... 172.22.1.228
IP NetMask....................................... 255.255.255.0
Gateway IP Addr.................................. 172.22.1.240
Domain...........................................
Name Server......................................
CAPWAP Path MTU.................................. 1485
Telnet State..................................... Disabled
Ssh State........................................ Disabled
Cisco AP Location................................ Conference Room
Cisco AP Group Name.............................. default-group
Primary Cisco Switch Name........................
Primary Cisco Switch IP Address.................. Not Configured
Secondary Cisco Switch Name......................
Secondary Cisco Switch IP Address................ Not Configured
Tertiary Cisco Switch Name.......................
Tertiary Cisco Switch IP Address................. Not Configured
Administrative State ............................ ADMIN_ENABLED
Operation State ................................. REGISTERED
Mirroring Mode .................................. Disabled
AP Mode ......................................... Local
Public Safety ................................... Disabled
AP SubMode ...................................... Not Configured
Remote AP Debug ................................. Disabled
Logging trap severity level ..................... informational
S/W  Version .................................... 6.0.199.4
Boot  Version ................................... 12.4.18.3
Mini IOS Version ................................ 3.0.51.0
Stats Reporting Period .......................... 180
LED State........................................ Enabled
PoE Pre-Standard Switch.......................... Disabled
PoE Power Injector MAC Addr...................... Override
Power Type/Mode.................................. Power injector / Normal mode
Number Of Slots.................................. 2
AP Model......................................... AIR-LAP1142N-A-K9
AP Image......................................... C1140-K9W8-M
IOS Version...................................... 12.4(21a)JHB1
Reset Button..................................... Enabled
AP Serial Number................................. FTX1440E2DL
AP Certificate Type.............................. Manufacture Installed
Management Frame Protection Validation........... Enabled (Global MFP Disabled)
AP User Mode..................................... AUTOMATIC
AP User Name..................................... Not Configured
AP Dot1x User Mode............................... Not Configured
AP Dot1x User Name............................... Not Configured
Cisco AP system logging host..................... 255.255.255.255
AP Up Time....................................... 60 days, 21 h 39 m 54 s
AP LWAPP Up Time................................. 60 days, 21 h 38 m 54 s
Join Date and Time............................... Sun Apr 22 17:53:28 2012
Join Taken Time.................................. 0 days, 00 h 00 m 59 s
Attributes for Slot  0
    Radio Type................................... RADIO_TYPE_80211n-2.4
    Administrative State ........................ ADMIN_ENABLED
    Operation State ............................. UP
    CellId ...................................... 0
    Station Configuration
      Configuration ............................. AUTOMATIC
      Number Of WLANs ........................... 3
      Medium Occupancy Limit .................... 100
      CFP Period ................................ 4
      CFP MaxDuration ........................... 60
      BSSID ..................................... b4:a4:e3:b4:05:80
      Operation Rate Set
        1000 Kilo Bits........................... MANDATORY
        2000 Kilo Bits........................... MANDATORY
        5500 Kilo Bits........................... MANDATORY
        11000 Kilo Bits.......................... MANDATORY
        6000 Kilo Bits........................... SUPPORTED
        9000 Kilo Bits........................... SUPPORTED
        12000 Kilo Bits.......................... SUPPORTED
        18000 Kilo Bits.......................... SUPPORTED
        24000 Kilo Bits.......................... SUPPORTED
        36000 Kilo Bits.......................... SUPPORTED
        48000 Kilo Bits.......................... SUPPORTED
        54000 Kilo Bits.......................... SUPPORTED
      MCS Set
        MCS 0.................................... SUPPORTED
        MCS 1.................................... SUPPORTED
        MCS 2.................................... SUPPORTED
        MCS 3.................................... SUPPORTED
        MCS 4.................................... SUPPORTED
        MCS 5.................................... SUPPORTED
        MCS 6.................................... SUPPORTED
        MCS 7.................................... SUPPORTED
        MCS 8.................................... SUPPORTED
        MCS 9.................................... SUPPORTED
        MCS 10................................... SUPPORTED
        MCS 11................................... SUPPORTED
        MCS 12................................... SUPPORTED
        MCS 13................................... SUPPORTED
        MCS 14................................... SUPPORTED
        MCS 15................................... SUPPORTED
      Beacon Period ............................. 100
      Fragmentation Threshold ................... 2346
      Multi Domain Capability Implemented ....... TRUE
      Multi Domain Capability Enabled ........... TRUE
      Country String ............................ US
      First Chan Num ............................ 1
      Number Of Channels ........................ 11
    MAC Operation Parameters
      Packet Retry Limit ........................ 64
    Tx Power
      Num Of Supported Power Levels ............. 8
      Tx Power Level 1 .......................... 20 dBm
      Tx Power Level 2 .......................... 17 dBm
      Tx Power Level 3 .......................... 14 dBm
      Tx Power Level 4 .......................... 11 dBm
      Tx Power Level 5 .......................... 8 dBm
      Tx Power Level 6 .......................... 5 dBm
      Tx Power Level 7 .......................... 2 dBm
      Tx Power Level 8 .......................... -1 dBm
      Tx Power Configuration .................... AUTOMATIC
      Current Tx Power Level .................... 1
    Phy OFDM parameters
      Configuration ............................. CUSTOMIZED
      Current Channel ........................... 6
      Extension Channel ......................... NONE
      Channel Width.............................. 20 Mhz
      Allowed Channel List....................... 1,2,3,4,5,6,7,8,9,10,11
      TI Threshold .............................. -50
      Legacy Tx Beamforming Configuration ....... AUTOMATIC
      Legacy Tx Beamforming ..................... DISABLED
      Antenna Type............................... INTERNAL_ANTENNA
      Internal Antenna Gain (in .5 dBi units).... 8
      Diversity.................................. DIVERSITY_ENABLED
      802.11n Antennas
        Tx
         A....................................... ENABLED
         B....................................... ENABLED
        Rx
         C....................................... ENABLED
    Performance Profile Parameters
      Interference threshold..................... 10 %
      Noise threshold............................  -70 dBm
      RF utilization threshold................... 80 %
      Data-rate threshold........................ 1000000 bps
      Operation Rate Set
      MCS Set
    Tx Power
    Phy OFDM parameters
      802.11n Antennas
        Tx
        Rx
      Client threshold........................... 12 clients
      Coverage SNR threshold..................... 12 dB
      Coverage exception level................... 25 %
      Client minimum exception level............. 3 clients
    Rogue Containment Information
    Containment Count............................ 0
Attributes for Slot  1
    Radio Type................................... RADIO_TYPE_80211n-5
    Radio Subband................................ RADIO_SUBBAND_ALL
      Operation Rate Set
        6000 Kilo Bits........................... MANDATORY
        12000 Kilo Bits.......................... MANDATORY
        24000 Kilo Bits.......................... MANDATORY
      MCS Set
      First Chan Num ............................ 36
      Number Of Channels ........................ 4
    Tx Power
      Num Of Supported Power Levels ............. 7
      Tx Power Level 1 .......................... 17 dBm
      Tx Power Level 2 .......................... 14 dBm
      Tx Power Level 3 .......................... 11 dBm
      Tx Power Level 4 .......................... 8 dBm
      Tx Power Level 5 .......................... 5 dBm
      Tx Power Level 6 .......................... 2 dBm
      Tx Power Level 7 .......................... -1 dBm
    Phy OFDM parameters
      Current Channel ........................... 149
      Extension Channel ......................... ABOVE
      Channel Width.............................. 40 Mhz
      Allowed Channel List....................... 36,40,44,48,52,56,60,64,100,
        ......................................... 104,108,112,116,132,136,140,
        ......................................... 149,153,157,161,165
      Internal Antenna Gain (in .5 dBi units).... 6
      802.11n Antennas
        Tx
        Rx
      Coverage SNR threshold..................... 16 dB
Cisco AP Identifier.............................. 2
Cisco AP Name.................................... Hyannis_Flr1
MAC Address...................................... 00:07:7d:2d:7b:f8
IP Address....................................... 172.22.1.227
Cisco AP Location................................ Dr Office
Boot  Version ................................... 12.4.23.0
PoE Power Injector MAC Addr...................... Disabled
AP Serial Number................................. FTX1522K5QR
AP Up Time....................................... 60 days, 21 h 41 m 48 s
AP LWAPP Up Time................................. 60 days, 21 h 40 m 47 s
Join Date and Time............................... Sun Apr 22 17:53:37 2012
Join Taken Time.................................. 0 days, 00 h 01 m 00 s
      BSSID ..................................... 20:37:06:0a:92:10
      Operation Rate Set
      MCS Set
    Tx Power
    Phy OFDM parameters
      802.11n Antennas
        Tx
        Rx
      Operation Rate Set
      MCS Set
    Tx Power
    Phy OFDM parameters
      802.11n Antennas
        Tx
        Rx
Cisco AP Identifier.............................. 6
Cisco AP Name.................................... Falmouth_AP
MAC Address...................................... 58:8d:09:37:c7:3e
IP Address....................................... 172.22.2.247
Gateway IP Addr.................................. 172.22.2.1
Cisco AP Location................................ Falmouth
AP Mode ......................................... H-Reap
AP Serial Number................................. FTX1441S2RD
H-REAP Vlan mode :............................... Disabled
H-REAP Backup Auth Radius Servers :
Static Primary Radius Server.................... Disabled
Static Secondary Radius Server.................. Disabled
Group Primary Radius Server..................... Disabled
Group Secondary Radius Server................... Disabled
Management Frame Protection Validation........... Disabled
AP Up Time....................................... 55 days, 16 h 21 m 05 s
AP LWAPP Up Time................................. 4 days, 21 h 59 m 32 s
Join Date and Time............................... Sun Jun 17 17:36:01 2012
Join Taken Time.................................. 0 days, 00 h 00 m 58 s
      BSSID ..................................... b4:14:89:1a:3e:a0
      Operation Rate Set
      MCS Set
    Tx Power
    Phy OFDM parameters
      802.11n Antennas
        Tx
        Rx
      Operation Rate Set
      MCS Set
    Tx Power
      Num Of Supported Power Levels ............. 6
      Tx Power Level 1 .......................... 14 dBm
      Tx Power Level 2 .......................... 11 dBm
      Tx Power Level 3 .......................... 8 dBm
      Tx Power Level 4 .......................... 5 dBm
      Tx Power Level 5 .......................... 2 dBm
      Tx Power Level 6 .......................... -1 dBm
    Phy OFDM parameters
      802.11n Antennas
        Tx
      802.11n Antennas
        Tx
        Rx
AP Airewave Director Configuration
AP Name.......................................... Hyannis_Flr2
  Slot ID........................................ 0
  Radio Type..................................... RADIO_TYPE_80211b/g
  Sub-band Type.................................. All
  Noise Information
    Noise Profile................................ PASSED
    Channel 1....................................  -92 dBm
    Channel 2....................................  -93 dBm
    Channel 3....................................  -91 dBm
    Channel 4....................................  -93 dBm
    Channel 5....................................  -90 dBm
    Channel 6....................................  -93 dBm
    Channel 7....................................  -94 dBm
    Channel 8....................................  -93 dBm
    Channel 9....................................  -94 dBm
    Channel 10...................................  -94 dBm
    Channel 11...................................  -95 dBm
  Interference Information
    Interference Profile......................... PASSED
    Channel 1.................................... -128 dBm @  0 % busy
    Channel 2.................................... -128 dBm @  0 % busy
    Channel 3.................................... -128 dBm @  0 % busy
    Channel 4.................................... -128 dBm @  0 % busy
    Channel 5.................................... -128 dBm @  0 % busy
    Channel 6....................................  -88 dBm @  2 % busy
    Channel 7.................................... -128 dBm @  0 % busy
    Channel 8.................................... -128 dBm @  0 % busy
    Channel 9.................................... -128 dBm @  0 % busy
    Channel 10...................................  -78 dBm @  1 % busy
    Channel 11...................................  -76 dBm @  1 % busy
  Load Information
    Load Profile................................. PASSED
    Receive Utilization.......................... 0 %
    Transmit Utilization......................... 7 %
    Channel Utilization.......................... 12 %
    Attached Clients............................. 1 clients
  Coverage Information
    Coverage Profile............................. PASSED
    Failed Clients............................... 0 clients
  Client Signal Strengths
    RSSI -100 dbm................................ 0 clients
    RSSI  -92 dbm................................ 0 clients
    RSSI  -84 dbm................................ 0 clients
    RSSI  -76 dbm................................ 1 clients
    RSSI  -68 dbm................................ 0 clients
    RSSI  -60 dbm................................ 0 clients
    RSSI  -52 dbm................................ 0 clients
  Client Signal To Noise Ratios
    SNR    0 dB.................................. 0 clients
    SNR    5 dB.................................. 0 clients
    SNR   10 dB.................................. 0 clients
    SNR   15 dB.................................. 0 clients
    SNR   20 dB.................................. 0 clients
    SNR   25 dB.................................. 1 clients
    SNR   30 dB.................................. 0 clients
    SNR   35 dB.................................. 0 clients
    SNR   40 dB.................................. 0 clients
    SNR   45 dB.................................. 0 clients
  Nearby APs
    AP 20:37:06:0a:92:10 slot 0..................  -79 dBm on   1 (172.22.1.222)
  Radar Information
  RF Parameter Recommendations
    Power Level.................................. 1
    RTS/CTS Threshold............................ 2347
    Fragmentation Tnreshold...................... 2346
    Antenna Pattern.............................. 0
  Slot ID........................................ 1
  Radio Type..................................... RADIO_TYPE_80211a
  Noise Information
    Channel 36................................... -100 dBm
    Channel 40...................................  -99 dBm
    Channel 44...................................  -99 dBm
    Channel 48...................................  -99 dBm
    Channel 52................................... -101 dBm
    Channel 56................................... -101 dBm
    Channel 60................................... -101 dBm
    Channel 64................................... -101 dBm
    Channel 100..................................  -99 dBm
    Channel 104..................................  -99 dBm
    Channel 108..................................  -99 dBm
    Channel 112..................................  -99 dBm
    Channel 116..................................  -99 dBm
    Channel 132..................................  -99 dBm
    Channel 136..................................  -96 dBm
    Channel 140..................................  -97 dBm
    Channel 149..................................  -94 dBm
    Channel 153..................................  -94 dBm
    Channel 157..................................  -95 dBm
    Channel 161..................................  -95 dBm
    Channel 165..................................  -96 dBm
    Channel 36................................... -128 dBm @  0 % busy
    Channel 40................................... -128 dBm @  0 % busy
    Channel 44................................... -128 dBm @  0 % busy
    Channel 48................................... -128 dBm @  0 % busy
    Channel 52................................... -128 dBm @  0 % busy
    Channel 56................................... -128 dBm @  0 % busy
    Channel 60................................... -128 dBm @  0 % busy
    Channel 64................................... -128 dBm @  0 % busy
    Channel 100.................................. -128 dBm @  0 % busy
    Channel 104.................................. -128 dBm @  0 % busy
    Channel 108.................................. -128 dBm @  0 % busy
    Channel 112.................................. -128 dBm @  0 % busy
    Channel 116.................................. -128 dBm @  0 % busy
    Channel 132.................................. -128 dBm @  0 % busy
    Channel 136.................................. -128 dBm @  0 % busy
    Channel 140.................................. -128 dBm @  0 % busy
    Channel 149.................................. -128 dBm @  0 % busy
    Channel 153.................................. -128 dBm @  0 % busy
    Channel 157.................................. -128 dBm @  0 % busy
    Channel 161.................................. -128 dBm @  0 % busy
    Channel 165.................................. -128 dBm @  0 % busy
        Rogue Histogram (20/40_ABOVE/40_BELOW)
    Channel 36...................................  0/ 0/ 0
    Channel 40...................................  0/ 0/ 0
    Channel 44...................................  0/ 0/ 0
    Channel 48...................................  0/ 0/ 0
    Channel 52...................................  0/ 0/ 0
    Channel 56...................................  0/ 0/ 0
    Channel 60...................................  0/ 0/ 0
    Channel 64...................................  0/ 0/ 0
    Channel 100..................................  0/ 0/ 0
    Channel 104..................................  0/ 0/ 0
    Channel 108..................................  0/ 0/ 0
    Channel 112..................................  0/ 0/ 0
    Channel 116..................................  0/ 0/ 0
    Channel 132..................................  0/ 0/ 0
    Channel 136..................................  0/ 0/ 0
    Channel 140..................................  0/ 0/ 0
    Channel 149..................................  0/ 0/ 0
    Channel 153..................................  0/ 0/ 0
    Channel 157..................................  0/ 0/ 0
    Channel 161..................................  0/ 0/ 0
    Channel 165..................................  0/ 0/ 0
  Load Information
    Transmit Utilization......................... 1 %
    Channel Utilization.......................... 0 %
    RSSI  -76 dbm................................ 0 clients
    RSSI  -60 dbm................................ 1 clients
    SNR   25 dB.................................. 0 clients
    SNR   30 dB.................................. 1 clients
  Nearby APs
  Radar Information
  Channel Assignment Information
    Current Channel Average Energy............... unknown
    Previous Channel Average Energy.............. unknown
    Channel Change Count......................... 0
    Last Channel Change Time..................... Sun Apr 22 17:53:28 2012
    Recommended Best Channel..................... 149
AP Name.......................................... Hyannis_Flr1
  Noise Information
    Channel 1....................................  -90 dBm
    Channel 3....................................  -93 dBm
    Channel 5....................................  -91 dBm
    Channel 7....................................  -92 dBm
    Channel 8....................................  -91 dBm
    Channel 9....................................  -93 dBm
    Channel 10...................................  -84 dBm
    Channel 11...................................  -93 dBm
--More or (q)uit current module or to abort   Channel 132..................................  -97 dBm
    Channel Utilization.......................... 5 %
    SNR   20 dB.................................. 1 clients
  Nearby APs
    AP b4:a4:e3:b4:05:80 slot 0..................  -75 dBm on   6 (172.22.1.222)
  Radar Information
  Noise Information
    Channel 36...................................  -99 dBm
    Channel 52...................................  -99 dBm
    Channel 56................................... -100 dBm
    Channel 60...................................  -98 dBm
    Channel 64...................................  -99 dBm
    Channel 100..................................  -98 dBm
    Channel 108..................................  -98 dBm
    Channel 112..................................  -97 dBm
    Channel 116..................................  -96 dBm
     Channel 136..................................  -98 dBm
    Channel 140..................................  -98 dBm
    Channel 149..................................  -96 dBm
    Channel 153..................................  -96 dBm
    Channel 157..................................  -96 dBm
    Channel 161..................................  -96 dBm
    Channel 165..................................  -95 dBm
  Load Information
    RSSI  -52 dbm................................ 1 clients
    SNR   45 dB.................................. 1 clients
  Nearby APs
  Radar Information
    Current Channel Average Energy...............    0 dBm
    Previous Channel Average Energy..............    0 dBm
    Channel Change Count......................... 1
    Last Channel Change Time..................... Sun Apr 22 17:59:31 2012
AP Name.......................................... Falmouth_AP
  Noise Information
    Channel 1....................................  -89 dBm
    Channel 3....................................  -95 dBm
    Channel 4....................................  -94 dBm
    Channel 5....................................  -95 dBm
    Channel 7....................................  -91 dBm
    Channel 8....................................  -94 dBm
    Channel 6.................................... -128 dBm @  0 % busy
    Channel 10................................... -128 dBm @  0 % busy
    Channel 11................................... -128 dBm @  0 % busy
  Load Information
    Transmit Utilization......................... 6 %
    Channel Utilization.......................... 6 %
    Attached Clients............................. 0 clients
    RSSI  -68 dbm................................ 1 clients
    SNR    0 dB.................................. 1 clients
  Nearby APs
  Radar Information
    Current Channel Average Energy...............  -82 dBm
    Previous Channel Average Energy..............  -66 dBm
    Channel Change Count......................... 3
    Last Channel Change Time..................... Thu Jun 21 15:43:36 2012
  Noise Information
    Channel 36................................... -101 dBm
    Channel 40................................... -100 dBm
    Channel 44................................... -102 dBm
    Channel 48................................... -101 dBm
    Channel 60................................... -100 dBm
    Channel 100..................................  -96 dBm
    Channel 104..................................  -92 dBm
    Channel 108..................................  -97 dBm
  Nearby APs
  Radar Information
  Noise Information
    Channel 112..................................  -98 dBm
    Channel 116..................................  -97 dBm
    Channel 132..................................  -94 dBm
    Channel 136..................................  -94 dBm
    Channel 140..................................  -94 dBm
    Channel 149..................................  -91 dBm
    Channel 153..................................  -90 dBm
    Channel 157..................................  -91 dBm
    Channel 161..................................  -93 dBm
    Channel 165..................................  -90 dBm
  Load Information
    Channel Utilization.......................... 20 %
  Nearby APs
  Radar Information
    Last Channel Change Time..................... Sun Jun 17 17:36:01 2012
802.11a Configuration
802.11a Network.................................. Enabled
11nSupport....................................... Enabled
      802.11a Low Band........................... Enabled
      802.11a Mid Band........................... Enabled
      802.11a High Band.......................... Enabled
802.11a Operational Rates
    802.11a 6M Rate.............................. Mandatory
    802.11a 9M Rate.............................. Supported
    802.11a 12M Rate............................. Mandatory
    802.11a 18M Rate............................. Supported
    802.11a 24M Rate............................. Mandatory
    802.11a 36M Rate............................. Supported
    802.11a 48M Rate............................. Supported
    802.11a 54M Rate............................. Supported
802.11n MCS Settings:
    MCS 0........................................ Supported
    MCS 1........................................ Supported
    MCS 2........................................ Supported
    MCS 3........................................ Supported
    MCS 4........................................ Supported
    MCS 5........................................ Supported
    MCS 6........................................ Supported
    MCS 7........................................ Supported
    MCS 8........................................ Supported
    MCS 9........................................ Supported
    MCS 10....................................... Supported
    MCS 11....................................... Supported
    MCS 12....................................... Supported
    MCS 13....................................... Supported
    MCS 14....................................... Supported
    MCS 15....................................... Supported
802.11n Status:
    A-MPDU Tx:
        Priority 0............................... Enabled
        Priority 1............................... Disabled
        Priority 2............................... Disabled
        Priority 3............................... Disabled
        Priority 4............................... Disabled
        Priority 5............................... Disabled
        Priority 6............................... Disabled
        Priority 7............................... Disabled
Beacon Interval.................................. 100
CF Pollable mandatory............................ Disabled
CF Poll Request mandatory........................ Disabled
CFP Period....................................... 4
CFP Maximum Duration............................. 60
Default Channel.................................. 36
Default Tx Power Level........................... 0
DTPC  Status..................................... Enabled
Fragmentation Threshold.......................... 2346
TI Threshold..................................... -50
Legacy Tx Beamforming setting.................... Disabled
Traffic Stream Metrics Status.................... Disabled
Expedited BW Request Status...................... Disabled
World Mode....................................... Enabled
EDCA profile type................................ default-wmm
Voice MAC optimization status.................... Disabled
Call Admision Control (CAC) configuration
Voice AC:
   Voice AC - Admission control (ACM)............ Disabled
   Voice max RF bandwidth........................ 75
   Voice reserved roaming bandwidth.............. 6
   Voice load-based CAC mode..................... Disabled
   Voice tspec inactivity timeout................ Disabled
   Voice Stream-Size............................. 84000
   Voice Max-Streams............................. 2
Video AC:
   Video AC - Admission control (ACM)............ Disabled
   Video max RF bandwidth........................ Infinite
   Video reserved roaming bandwidth.............. 0
802.11a Advanced Configuration
AP Name                          MAC Address        Admin State  Operation State   Channel TxPower
Hyannis_Flr2                     b4:a4:e3:b4:05:80    ENABLED      UP                (149,153)*   1(*)
Hyannis_Flr1                     20:37:06:0a:92:10    ENABLED      UP                (149,153)*   1(*)
Falmouth_AP                      b4:14:89:1a:3e:a0    ENABLED      UP                (149,153)*   1(*)
802.11a Airewave Director Configuration
RF Event and Performance Logging
  Channel Update Logging......................... Off
  Coverage Profile Logging....................... Off
  Foreign Profile Logging........................ Off
  Load Profile Logging........................... Off
  Noise Profile Logging.......................... Off
  Performance Profile Logging.................... Off
  TxPower Update Logging......................... Off
Default 802.11a AP performance profiles
  802.11a Global Interference threshold.......... 10 %
  802.11a Global noise threshold................. -70 dBm
  802.11a Global RF utilization threshold........ 80 %
  802.11a Global throughput threshold............ 1000000 bps
  802.11a Global clients threshold............... 12 clients
Default 802.11a AP monitoring
  802.11a Monitor Mode........................... enable
  802.11a Monitor Mode for Mesh AP Backhaul...... disable
  802.11a Monitor Channels....................... Country channels
  802.11a AP Coverage Interval................... 180 seconds
  802.11a AP Load Interval....................... 60 seconds
  802.11a AP Noise Interval...................... 180 seconds
  802.11a AP Signal Strength Interval............ 60 seconds
Automatic Transmit Power Assignment
  Transmit Power Assignment Mode................. AUTO
  Transmit Power Update Interval................. 600 seconds
  Transmit Power Threshold....................... -70 dBm
  Transmit Power Neighbor Count.................. 3 APs
  Min Transmit Power............................. -10 dBm
  Max Transmit Power............................. 30 dBm
  Transmit Power Update Contribution............. SNI.
  Transmit Power Assignment Leader............... e0:5f:b9:63:d4:e0
  Last Run....................................... 18 seconds ago
Coverage Hole Detection
  802.11a Coverage Hole Detection Mode........... Enabled
  802.11a Coverage Voice Packet Count............ 100 packets
  802.11a Coverage Voice Packet Percentage....... 50%
  802.11a Coverage Voice RSSI Threshold.......... -80 dBm
  802.11a Coverage Data Packet Count............. 50 packets
  802.11a Coverage Data Packet Percentage........ 50%
  802.11a Coverage Data RSSI Threshold........... -80 dBm
  802.11a Global coverage exception level........ 25 %
  802.11a Global client minimum exception lev.... 3 clients
Automatic Channel Assignment
  Channel Assignment Mode........................ AUTO
  Channel Update Interval........................ 600 seconds
  Anchor time (Hour of the day).................. 0
  Channel Update Contribution.................... SNI.
  Channel Assignment Leader...................... e0:5f:b9:63:d4:e0
  DCA Sensitivity Level.......................... MEDIUM (15 dB)
  DCA 802.11n Channel Width...................... 40 MHz
  DCA Minimum Energy Limit....................... -95 dBm
  Channel Energy Levels
    Minimum...................................... 0 dBm
    Average...................................... 0 dBm
    Maximum...................................... 0 dBm
  Channel Dwell Times
    Minimum...................................... 4 days, 22 h 02 m 57 s
    Average...................................... 42 days, 05 h 49 m 18 s
    Maximum...................................... 60 days, 21 h 45 m 30 s
  802.11a 5 GHz Auto-RF Channel List
    Allowed Channel List......................... 36,40,44,48,52,56,60,64,100,
                                                  149,153,157,161
    Unused Channel List.......................... 165
  802.11a 4.9 GHz Auto-RF Channel List
    Unused Channel List.......................... 1,2,3,4,5,6,7,8,9,10,11,12,
                                                  13,14,15,16,17,18,19,20,21,
                                                  22,23,24,25,26
  DCA Outdoor AP option.......................... Disabled
Radio RF Grouping
  802.11a Group Mode............................. AUTO
  802.11a Group Update Interval.................. 600 seconds
  802.11a Group Leader........................... e0:5f:b9:63:d4:e0
    802.11a Group Member......................... e0:5f:b9:63:d4:e0
  802.11a Last Run............................... 18 seconds ago
802.11b Configuration
802.11b Network.................................. Enabled
11gSupport....................................... Enabled
802.11b/g Operational Rates
    802.11b/g 1M Rate............................ Mandatory
    802.11b/g 2M Rate............................ Mandatory
    802.11b/g 5.5M Rate.......................... Mandatory
    802.11b/g 11M Rate........................... Mandatory
    802.11g 6M Rate.............................. Supported
    802.11g 9M Rate.............................. Supported
    802.11g 12M Rate............................. Supported
    802.11g 18M Rate............................. Supported
    802.11g 24M Rate............................. Supported
    802.11g 36M Rate............................. Supported
    802.11g 48M Rate............................. Supported
    802.11g 54M Rate............................. Supported
802.11n Status:
    A-MPDU Tx:
CF Pollable mode................................. Disabled
Default Channel.................................. 1
Call Admission Limit  ........................... 105
G711 CU Quantum ................................. 15
ED Threshold..................................... -50
PBCC mandatory................................... Disabled
RTS Threshold.................................... 2347
Short Preamble mandatory......................... Enabled
Short Retry Limit................................ 7
Faster Carrier Tracking Loop..................... Disabled
   Video max RF bandwidth........................ 50
802.11b Advanced Configuration
Hyannis_Flr2                     b4:a4:e3:b4:05:80    ENABLED      UP                6        1(*)
Hyannis_Flr1                     20:37:06:0a:92:10    ENABLED      UP                1        1(*)
Falmouth_AP                      b4:14:89:1a:3e:a0    ENABLED      UP                1*       1(*)
802.11b Airewave Director Configuration
  Transmit Power Update Logging.................. Off
Default 802.11b AP performance profiles
  802.11b Global Interference threshold.......... 10 %
  802.11b Global noise threshold................. -70 dBm
  802.11b Global RF utilization threshold........ 80 %
  802.11b Global throughput threshold............ 1000000 bps
  802.11b Global clients threshold............... 12 clients
Default 802.11b AP monitoring
  802.11b Monitor Mode........................... enable
  802.11b Monitor Channels....................... Country channels
  802.11b AP Coverage Interval................... 180 seconds
  802.11b AP Load Interval....................... 60 seconds
  802.11b AP Noise Interval...................... 180 seconds
  802.11b AP Signal Strength Interval............ 60 seconds
  Last Run....................................... 46 seconds ago
  802.11b Coverage Hole Detection Mode........... Enabled
  802.11b Coverage Voice Packet Count............ 100 packets
  802.11b Coverage Voice Packet Percentage....... 50%
  802.11b Coverage Voice RSSI Threshold.......... -80 dBm
  802.11b Coverage Data Packet Count............. 50 packets
  802.11b Coverage Data Packet Percentage........ 50%
  802.11b Coverage Data RSSI Threshold........... -80 dBm
  802.11b Global coverage exception level........ 25 %
  802.11b Global client minimum exception lev.... 3 clients
  DCA Sensitivity Level: ...................... MEDIUM (10 dB)
    Minimum...................................... -82 dBm
    Average...................................... -82 dBm
    Maximum...................................... -82 dBm
  Channel Dwell Times
    Minimum...................................... 0 days, 23 h 55 m 48 s
    Average...................................... 40 days, 22 h 29 m 10 s
    Maximum...................................... 60 days, 21 h 45 m 56 s
  802.11b Auto-RF Allowed Channel List........... 1,6,11
  Auto-RF Unused Channel List.................... 2,3,4,5,7,8,9,10
Radio RF Grouping
  802.11b Group Mode............................. AUTO
  802.11b Group Update Interval.................. 600 seconds
  802.11b Group Leader........................... e0:5f:b9:63:d4:e0
    802.11b Group Member......................... e0:5f:b9:63:d4:e0
  802.11b Last Run............................... 46 seconds ago
Mobility Configuration
Symmetric Mobility Tunneling (current) .......... Enabled
Symmetric Mobility Tunneling (after reboot) ..... Enabled
Mobility Protocol Port........................... 16666
Default Mobility Domain.......................... TCS
Multicast Mode .................................. Disabled
Mobility Domain ID for 802.11r................... 0x8212
Mobility Keepalive Interval...................... 10
Mobility Keepalive Count......................... 3
Mobility Group Members Configured................ 1
Mobility Control Message DSCP Value.............. 0
Controllers configured in the Mobility Group
MAC Address        IP Address       Group Name                        Multicast IP     Status
e0:5f:b9:63:d4:e0  172.22.1.222     TCS                               0.0.0.0          Up
Probe request filtering..........................  Enabled
Probes fwd to controller per client per radio....  0
Probe request rate-limiting interval.............  500 msec
EAP-Identity-Request Timeout (seconds)........... 30
EAP-Identity-Request Max Retries................. 2
EAP Key-Index for Dynamic WEP.................... 0
EAP Max-Login Ignore Identity Response........... enable
EAP-Request Timeout (seconds).................... 30
EAP-Request Max Retries.......................... 2
EAPOL-Key Timeout (milliseconds)................. 1000
EAPOL-Key Max Retries............................ 2
dot11-padding.................................... Disabled
Authentication Response Timeout (seconds)........ 10
Rogue Entry Timeout (seconds).................... 1200
AP Heart Beat Timeout (seconds).................. 30
AP Discovery Timeout (seconds)................... 10
AP Local mode Fast Heartbeat (seconds)........... disable
AP Hreap mode Fast Heartbeat (seconds)........... disable
AP Primary Discovery Timeout (seconds)........... 120
AP Primed Join Timeout (seconds)................. 0
Location Configuration
RFID Tag data Collection......................... Enabled
RFID  timeout.................................... 1200 seconds
RFID mobility.................................... Oui:00:14:7e : Vendor:pango  State:Disabled
Interface Configuration
Interface Name................................... ap-manager
MAC Address...................................... e0:5f:b9:63:d4:e0
IP Address....................................... 172.22.1.223
IP Netmask....................................... 255.255.255.0
IP Gateway....................................... 172.22.1.240
External NAT IP State............................ Disabled
External NAT IP Address.......................... 0.0.0.0
VLAN............................................. untagged
Physical Port.................................... 1
Primary DHCP Server.............................. 172.22.1.15
Secondary DHCP Server............................ Unconfigured
DHCP Option 82................................... Disabled
ACL.............................................. Unconfigured
AP Manager....................................... Yes
Guest Interface.................................. No
Interface Name................................... management
IP Address....................................... 172.22.1.222
Quarantine-vlan.................................. 0
AP Manager....................................... No
Interface Name................................... tcs
IP Address....................................... 172.22.6.2
IP Netmask....................................... 255.255.0.0
VLAN............................................. 6
Primary DHCP Server.............................. 172.22.1.222
Interface Name................................... virtual
IP Address....................................... 1.1.1.1
Virtual DNS Host Name............................ Disabled
WLAN Configuration
WLAN Identifier.................................. 1
Profile Name..................................... TCS-Wlan
Network Name (SSID).............................. TCS-Wlan
Status........................................... Enabled
MAC Filtering.................................... Disabled
Broadcast SSID................................... Enabled
AAA Policy Override.............................. Disabled
  NAC-State...................................... Disabled
  Quarantine VLAN................................ 0
Number of Active Clients......................... 0
Exclusionlist Timeout............................ 60 seconds
Session Timeout.................................. 1800 seconds
CHD per WLAN..................................... Enabled
Webauth DHCP exclusion........................... Disabled
Interface........................................ management
WLAN ACL......................................... unconfigured
DHCP Server...................................... Default
DHCP Address Assignment Required................. Disabled
Quality of Service............................... Silver (best effort)
Scan Defer Priority.............................. 5,6
Scan Defer Time.................................. 100 milliseconds
WMM.............................................. Allowed
Media Stream Multicast-direct.................... Disabled
CCX - AironetIe Support.......................... Enabled
CCX - Gratuitous ProbeResponse (GPR)............. Disabled
CCX - Diagnostics Channel Capability............. Disabled
Dot11-Phone Mode (7920).......................... Disabled
Wired Protocol................................... None
IPv6 Support..................................... Disabled
Peer-to-Peer Blocking Action..................... Disabled
Radio Policy..................................... All
DTIM period for 802.11a radio.................... 1
DTIM period for 802.11b radio.................... 1
Radius Servers
   Authentication................................ Global Servers
   Accounting.................................... Global Servers
   Dynamic Interface............................. Disabled
Local EAP Authentication......................... Disabled
Security
   802.11 Authentication:........................ Open System
   Static WEP Keys............................... Disabled
   802.1X........................................ Disabled
   Wi-Fi Protected Access (WPA/WPA2)............. Enabled
      WPA (SSN IE)............................... Enabled
         TKIP Cipher............................. Enabled
         AES Cipher.............................. Enabled
      WPA2 (RSN IE).............................. Enabled
                                                               Auth Key Management
         802.1x.................................. Disabled
         PSK..................................... Enabled
         CCKM.................................... Disabled
         FT(802.11r)............................. Disabled
         FT-PSK(802.11r)......................... Disabled
FT Reassociation Timeout......................... 20
FT Over-The-Air mode............................. Enabled
FT Over-The-Ds mode.............................. Enabled
   CKIP ......................................... Disabled
   Web Based Authentication...................... Disabled
   Web-Passthrough............................... Disabled
   Conditional Web Redirect...................... Disabled
   Splash-Page Web Redirect...................... Disabled
   Auto Anchor................................... Disabled
   H-REAP Local Switching........................ Disabled
   H-REAP Learn IP Address....................... Enabled
   Infrastructure MFP protection................. Enabled (Global Infrastructure MFP Disabled)
   Client MFP.................................... Optional
   Tkip MIC Countermeasure Hold-down Timer....... 60
Call Snooping.................................... Disabled
Band Select...................................... Enabled
Load Balancing................................... Enabled
Mobility Anchor List
WLAN ID     IP Address            Status
WLAN Configuration
WLAN Identifier.................................. 2
Profile Name..................................... TCS_Fal
Network Name (SSID).............................. TCS_Fal
Number of Active Clients......................... 2
Radius Servers
Security
         AES Cipher.............................. Disabled
         TKIP Cipher............................. Disabled
                                                               Auth Key Management
                                                               Auth Key Management
   H-REAP Local Switching........................ Enabled
WLAN Configuration
WLAN Identifier.................................. 3
Profile Name..................................... TCS-Guest
Network Name (SSID).............................. TCS-Guest
Interface........................................ tcs
Radius Servers
Security
                                                               Auth Key Management
ACL Configuration
CPU ACL Configuration
CPU Acl Name................................ NOT CONFIGURED
Wireless Traffic............................ Disabled
Wired Traffic............................... Disabled
RADIUS Configuration
Vendor Id Backward Compatibility................. Disabled
Call Station Id Case............................. lower
Call Station Id Type............................. IP Address
Aggressive Failover.............................. Enabled
Keywrap.......................................... Disabled
Fallback Test:
    Test Mode.................................... Off
    Probe User Name.............................. cisco-probe
    Interval (in seconds)........................ 300
MAC Delimiter for Authentication Messages........ hyphen
MAC Delimiter for Accounting Messages............ hyphen
Authentication Servers
Idx  Type  Server Address    Port    State     Tout  RFC3576  IPSec - AuthMode/Phase1/Group/Lifetime/Auth/Encr
Accounting Servers
TACACS Configuration
Idx  Server Address    Port    State     Tout
Authorization Servers
Accounting Servers
LDAP Configuration
Local EAP Configuration
User credentials database search order:
    Primary ..................................... Local DB
Timer:
    Active timeout .............................. 300
Configured EAP profiles:
EAP Method configuration:
    EAP-FAST:
      Server key ................................
      TTL for the PAC ........................... 10
      Anonymous provision allowed ............... Yes
      Authority ID .............................. 436973636f0000000000000000000000
      Authority Information ..................... Cisco A-ID
HREAP Group Summary
HREAP Group Summary: Count: 1
Group Name                # Aps
Fal                        0
HREAP Group Detail
HREAP Group Name - Fal
Number of Ap's in Group: 0
Group Radius Servers Settings:
Primary Server Index............................ Disabled
Secondary Server Index.......................... Disabled
Group Radius AP Settings:
AP RADIUS server............ Disabled
EAP-FAST Auth............... Disabled
LEAP Auth................... Disabled
Server Key Auto Generated... No
Server Key..................
Authority ID................ 436973636f0000000000000000000000
Authority Info.............. Cisco A_ID
PAC Timeout................. 0
Number of User's in Group: 0
Route  Info
Number of Routes................................. 0
Destination Network          Netmask               Gateway
Qos Queue Length Info
Platinum queue length............................ 100
Gold queue length................................  75
Silver queue length..............................  50
Bronze queue length..............................  25
Mac Filter Info
Accounting Servers
LDAP Configuration
Timer:
    EAP-FAST:
HREAP Group Summary
Group Name                # Aps
Fal                        0
HREAP Group Detail
Route  Info
Mac Filter Info
Authorization List
Authorize MIC APs against AAA ................... disabled
Authorize LSC APs against Auth-List ............. disabled
Allow APs with MIC - Manufactured Installed C.... disabled
Allow APs with SSC - Self-Signed Certificate..... disabled
Allow APs with LSC - Locally Significant Cert.... disabled
Load Balancing Info
Aggressive Load Balancing........................ Disabled
Aggressive Load Balancing Window................. 5 clients
Aggressive Load Balancing Denial Count........... 3
                                                    Statistics
Total Denied Count............................... 0 clients
Total Denial Sent................................ 0 messages
Exceeded Denial Max Limit Count.................. 0 times
None 5G Candidate Count.......................... 0 times
None 2.4G Candidate Count........................ 0 times
Dhcp Scope Info
               Scope: TCS-Guest
Enabled.......................................... No
Lease Time....................................... 86400 (1 day )
Pool Start....................................... 172.22.6.100
Pool End......................................... 172.22.6.200
Network.......................................... 172.22.6.0
Netmask.......................................... 255.255.255.0
Default Routers.................................. 172.22.1.240  0.0.0.0  0.0.0.0
DNS Domain.......................................
DNS.............................................. 0.0.0.0  0.0.0.0  0.0.0.0
Netbios Name Servers............................. 0.0.0.0  0.0.0.0  0.0.0.0
Exclusion List ConfigurationUnable to retrieve exclusion-list entry
CDP Configuration
Country Channels Configuration
Configured Country............................. US  - United States
      KEY: * = Channel is legal in this country and may be configured manually.
           A = Channel is the Auto-RF default in this country.
           . = Channel is not legal in this country.
           C = Channel has been configured for use by Auto-RF.
           x = Channel is available to be configured for use by Auto-RF.
         (-,-) = (indoor, outdoor) regulatory doamin allowed by this country.
    802.11bg     :
    Channels     :                   1 1 1 1 1
                 : 1 2 3 4 5 6 7 8 9 0 1 2 3 4
US (-A   ,-AB  ): A * * * * A * * * * A . . .
    802.11a      :                         1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1
    Channels     : 3 3 3 4 4 4 4 4 5 5 6 6 0 0 0 1 1 2 2 2 3 3 4 4 5 5 6 6
                 : 4 6 8 0 2 4 6 8 2 6 0 4 0 4 8 2 6 0 4 8 2 6 0 9 3 7 1 5
US (-A   ,-AB  ): . A . A . A . A A A A A * * * * * . . . * * * A A A A *
4.9GHz 802.11a  :
    Channels     :                   1 1 1 1 1 1 1 1 1 1 2 2 2 2 2 2 2
                 : 1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6
US (-A   ,-AB  ): * * * * * * * * * * * * * * * * * * * A * * * * * A
WPS Configuration Summary
Auto-Immune
  Auto-Immune.................................... Disabled
Client Exclusion Policy
  Excessive 802.11-association failures.......... Enabled
  Excessive 802.11-authentication failures....... Enabled
  Excessive 802.1x-authentication................ Enabled
  IP-theft....................................... Enabled
  Excessive Web authentication failure........... Enabled
Signature Policy
  Signature Processing........................... Enabled
Custom Web Configuration
Radius Authentication Method..................... PAP
Cisco Logo....................................... Enabled
CustomLogo....................................... None
Custom Title..................................... TCS Wireless Lan
Custom Message................................... Abuse it and you're gone!
Custom Redirect URL.............................. www.tcsma.com
Web Authentication Type.......................... Internal Default
External Web Authentication URL.................. None
Configuration Per Profile:
Rogue AP Configuration
Rogue Location Discovery Protocol................ Disabled
Rogue on wire Auto-Contain....................... Disabled
Rogue using our SSID Auto-Contain................ Disabled
Valid client on rogue AP Auto-Contain............ Disabled
Rogue AP timeout................................. 1200
MAC Address        Classification     # APs # Clients Last Heard
00:18:f8:ac:02:07  Unclassified       1     0         Fri Jun 22 15:42:01 2012
00:1d:7e:69:83:22  Unclassified       1     0         Fri Jun 22 15:33:01 2012
00:22:3f:77:b8:a2  Unclassified       2     0         Fri Jun 22 15:40:45 2012
00:22:75:9b:ed:07  Unclassified       1     0         Fri Jun 22 15:41:24 2012
00:3a:99:4c:a1:00  Unclassified       1     0         Fri Jun 22 15:29:24 2012
00:7f:28:92:b2:8b  Unclassified       2     0         Fri Jun 22 15:42:01 2012
0c:d5:02:5a:4c:e8  Unclassified       1     0         Fri Jun 22 15:41:24 2012
c0:3f:0e:9f:78:7a  Unclassified       1     0         Fri Jun 22 15:27:01 2012
c0:c1:c0:93:1d:59  Unclassified       2     0         Fri Jun 22 15:31:45 2012
Adhoc Rogue Configuration
Detect and report Ad-Hoc Networks................ Enabled
--More-- or (q)uit
Auto-Contain Ad-Hoc Networks..................... Disabled
Client MAC Address  Adhoc BSSID         State              # APs   Last Heard
d8:d3:85:44:48:64   5a:c0:52:e9:a8:d5   Alert              1        Fri Jun 22 15:38:24 2012
Rogue Client Configuration
Validate rogue clients against AAA............... Disabled
MAC Address        State              # APs Last Heard
Ignore List Configuration
MAC Address
Rogue Rule Configuration
Priority Rule Name               State    Type          Match Hit Count
--More-- or (q)uit
(Cisco Controller) >
Very frustrated. Another guest / corp lan config question
Hello Tim
oooohh yeah.  so would that be the subinterface i add to the router for that vlan?
how does everything else look?
Thank you for all your help.  One final thing, do you know any good recourses that show best practices, different scenario's etc for setting up a WLAN?  i've read 3 books and countless hours of CBT's but none prepared me for actually getting this setup correctly and working in a production environmant. that was frustrating because i am very interested in the wireless/mobile technology.
783
