You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
Very Low Bandwidth on AIR-CAP1602 FlexConnect Local and vWLC
I am having some hard time with the bandwidth on the Access Points managed by the vWLC. The WAN link we have is 80Mbps but the download speed measured on the laptop connected to one of the APs shows less than 1Mbps, usually 0.20Mbps, Internet browsing is not even possible with this speed. The wireless card on the laptop (Windows machine) shows the connection speed anything between 60 to 140Mbps.
The APs are configured with FlexConnect mode becasue teh vWLC is on the remote site.
Anybody had a similar problem? How could I start troubleshooting it?
Thanks in advance,
Remi
  • Getting Started with Wireless
VIP Purple
Hi Remi,
Does your WLAN configured for FlexConnect Local Switching or Central Switching ? I hope it is local switching.
I would check the following
1. Data Rates configured in 802.11a/n & 802.11b/g/n bands. I would disable all data rates below 12Mbps
2. Under WLAN security set to WPA2/AES
3. Under WLAN QoS WMM settings "Required" or "Allow"
Attached your "show wlan output & "show client detail " output to check
Rasika
**** Pls rate all useful responses ***
Hi Rasika,
Thanks for responding to my post. Answering your questions yes I have all the WLANs configured for FlexConnect with local switching. Also have 2 Flex Connect groups as I have 2 remote locations with APs.
On all WLANs I had WPA2 with AES and TKIP enable so I disabled TKIP.
Disabled all the rates below 12Mbps on 802.11a/n & 802.11b/g/n bands.
WLAN QoS WMM settings were on Allow by default.
Attaching the outputs you requested.
(Cisco Controller) >show wlan 4
WLAN Identifier.................................. 4
Profile Name..................................... WiFi Docentes
Network Name (SSID).............................. 3014WD
Status........................................... Enabled
MAC Filtering.................................... Disabled
Broadcast SSID................................... Enabled
AAA Policy Override.............................. Disabled
Network Admission Control
  Client Profiling Status ....................... Disabled
   DHCP ......................................... Disabled
   HTTP ......................................... Disabled
  Radius-NAC State............................... Disabled
  SNMP-NAC State................................. Disabled
  Quarantine VLAN................................ 0
Maximum number of Associated Clients............. 0
Maximum number of Clients per AP Radio........... 35
Number of Active Clients......................... 3
Exclusionlist Timeout............................ 60 seconds
Session Timeout.................................. 43200 seconds
User Idle Timeout................................ 43200 seconds
--More-- or (q)uit
User Idle Threshold.............................. 0 Bytes
NAS-identifier................................... argos-vwlc
CHD per WLAN..................................... Enabled
Webauth DHCP exclusion........................... Disabled
Interface........................................ argos-docentes
Multicast Interface.............................. Not Configured
WLAN IPv4 ACL.................................... unconfigured
WLAN IPv6 ACL.................................... unconfigured
mDNS Status...................................... Disabled
mDNS Profile Name................................ unconfigured
DHCP Server...................................... Default
DHCP Address Assignment Required................. Disabled
Static IP client tunneling....................... Disabled
Quality of Service............................... Silver
Per-SSID Rate Limits............................. Upstream      Downstream
Average Data Rate................................   0             0
Average Realtime Data Rate.......................   0             0
Burst Data Rate..................................   0             0
Burst Realtime Data Rate.........................   0             0
Per-Client Rate Limits........................... Upstream      Downstream
--More-- or (q)uit
Scan Defer Priority.............................. 4,5,6
Scan Defer Time.................................. 100 milliseconds
WMM.............................................. Allowed
WMM UAPSD Compliant Client Support............... Disabled
Media Stream Multicast-direct.................... Disabled
CCX - AironetIe Support.......................... Enabled
CCX - Gratuitous ProbeResponse (GPR)............. Disabled
CCX - Diagnostics Channel Capability............. Disabled
Dot11-Phone Mode (7920).......................... Disabled
Wired Protocol................................... None
Passive Client Feature........................... Disabled
Peer-to-Peer Blocking Action..................... Disabled
Radio Policy..................................... All
DTIM period for 802.11a radio.................... 1
DTIM period for 802.11b radio.................... 1
Radius Servers
   Authentication................................ Global Servers
   Accounting.................................... Global Servers
      Interim Update............................. Disabled
   Dynamic Interface............................. Disabled
   Dynamic Interface Priority.................... wlan
Local EAP Authentication......................... Disabled
--More-- or (q)uit
Security
   802.11 Authentication:........................ Open System
   FT Support.................................... Disabled
   Static WEP Keys............................... Disabled
   802.1X........................................ Disabled
   Wi-Fi Protected Access (WPA/WPA2)............. Enabled
      WPA (SSN IE)............................... Disabled
      WPA2 (RSN IE).............................. Enabled
         TKIP Cipher............................. Disabled
         AES Cipher.............................. Enabled
                                                               Auth Key Management
         802.1x.................................. Disabled
         PSK..................................... Enabled
         CCKM.................................... Disabled
         FT-1X(802.11r).......................... Disabled
         FT-PSK(802.11r)......................... Disabled
         PMF-1X(802.11w)......................... Disabled
         PMF-PSK(802.11w)........................ Disabled
      FT Reassociation Timeout................... 20
      FT Over-The-DS mode........................ Enabled
      GTK Randomization.......................... Disabled
      SKC Cache Support.......................... Disabled
--More-- or (q)uit
      CCKM TSF Tolerance......................... 1000
   WAPI.......................................... Disabled
   Wi-Fi Direct policy configured................ Disabled
   EAP-Passthrough............................... Disabled
   CKIP ......................................... Disabled
   Web Based Authentication...................... Disabled
   Web-Passthrough............................... Disabled
   Conditional Web Redirect...................... Disabled
   Splash-Page Web Redirect...................... Disabled
   Auto Anchor................................... Disabled
   FlexConnect Local Switching................... Enabled
   flexconnect Central Dhcp Flag................. Disabled
   flexconnect nat-pat Flag...................... Disabled
   flexconnect Dns Override Flag................. Disabled
   FlexConnect Vlan based Central Switching ..... Disabled
   FlexConnect Local Authentication.............. Disabled
   FlexConnect Learn IP Address.................. Disabled
   Client MFP.................................... Optional
   PMF........................................... Disabled
   PMF Association Comeback Time................. 1
   PMF SA Query RetryTimeout..................... 200
   Tkip MIC Countermeasure Hold-down Timer....... 60
AVC Visibilty.................................... Disabled
--More-- or (q)uit
AVC Profile Name................................. None
Flow Monitor Name................................ None
Call Snooping.................................... Disabled
Roamed Call Re-Anchor Policy..................... Disabled
SIP CAC Fail Send-486-Busy Policy................ Enabled
SIP CAC Fail Send Dis-Association Policy......... Disabled
KTS based CAC Policy............................. Disabled
Assisted Roaming Prediction Optimization......... Disabled
802.11k Neighbor List............................ Disabled
802.11k Neighbor List Dual Band.................. Disabled
Band Select...................................... Disabled
Load Balancing................................... Disabled
Multicast Buffer................................. Disabled
Mobility Anchor List
WLAN ID     IP Address            Status
802.11u........................................ Disabled
MSAP Services.................................. Disabled
--More-- or (q)uit
(Cisco Controller) >show client detail c4:62:ea:3d:37:e2
Client MAC Address............................... c4:62:ea:3d:37:e2
Client Username ................................. N/A
AP MAC Address................................... 7c:95:f3:6d:b9:80
AP Name.......................................... arg-col-primA-ap17
Client State..................................... Associated
Client NAC OOB State............................. Access
Wireless LAN Id.................................. 4
Hotspot (802.11u)................................ Not Supported
BSSID............................................ 7c:95:f3:6d:b9:81
Connected For ................................... 87 secs
Channel.......................................... 6
IP Address....................................... 10.10.32.231
Gateway Address.................................. 10.10.32.1
Netmask.......................................... 255.255.252.0
Association Id................................... 4
Authentication Algorithm......................... Open System
Reason Code...................................... 1
Status Code...................................... 0
Client CCX version............................... No CCX support
QoS Level........................................ Silver
802.1P Priority Tag.............................. disabled
--More-- or (q)uit
CTS Security Group Tag........................... Not Applicable
KTS CAC Capability............................... No
WMM Support...................................... Enabled
  APSD ACs.......................................  BK  BE  VI  VO
Power Save....................................... ON
Current Rate..................................... m7
Supported Rates.................................. 1.0,2.0,5.5,11.0,6.0,9.0,
    ............................................. 12.0,18.0,24.0,36.0,48.0,
    ............................................. 54.0
Mobility State................................... Local
Mobility Move Count.............................. 0
Security Policy Completed........................ Yes
Policy Manager State............................. RUN
Policy Manager Rule Created...................... Yes
Audit Session ID................................. none
IPv4 ACL Name.................................... none
IPv4 ACL Applied Status.......................... Unavailable
IPv6 ACL Name.................................... none
IPv6 ACL Applied Status.......................... Unavailable
mDNS Profile Name................................ none
No. of mDNS Services Advertised.................. 0
Policy Type...................................... WPA2
--More-- or (q)uit
Authentication Key Management.................... PSK
Encryption Cipher................................ CCMP (AES)
Protected Management Frame ...................... No
Management Frame Protection...................... No
EAP Type......................................... Unknown
FlexConnect Data Switching....................... Local
FlexConnect Dhcp Status.......................... Local
FlexConnect Vlan Based Central Switching......... No
FlexConnect Authentication....................... Central
Quarantine VLAN.................................. 0
Access VLAN...................................... 60
Client Capabilities:
      CF Pollable................................ Not implemented
      CF Poll Request............................ Not implemented
      Short Preamble............................. Implemented
      PBCC....................................... Not implemented
      Channel Agility............................ Not implemented
      Listen Interval............................ 10
      Fast BSS Transition........................ Not implemented
Client Wifi Direct Capabilities:
      WFD capable................................ No
      Manged WFD capable......................... No
      Cross Connection Capable................... No
--More-- or (q)uit
      Support Concurrent Operation............... No
Fast BSS Transition Details:
Client Statistics:
      Number of Bytes Received................... 2880
      Number of Bytes Sent....................... 4765
      Number of Packets Received................. 34
      Number of Packets Sent..................... 25
      Number of Interim-Update Sent.............. 0
      Number of EAP Id Request Msg Timeouts...... 0
      Number of EAP Id Request Msg Failures...... 0
      Number of EAP Request Msg Timeouts......... 0
      Number of EAP Request Msg Failures......... 0
      Number of EAP Key Msg Timeouts............. 0
      Number of EAP Key Msg Failures............. 0
      Number of Data Retries..................... 14
      Number of RTS Retries...................... 0
      Number of Duplicate Received Packets....... 0
      Number of Decrypt Failed Packets........... 0
      Number of Mic Failured Packets............. 0
      Number of Mic Missing Packets.............. 0
      Number of RA Packets Dropped............... 0
      Number of Policy Errors.................... 0
      Radio Signal Strength Indicator............ -62 dBm
--More-- or (q)uit
      Signal to Noise Ratio...................... 24 dB
Client Rate Limiting Statistics:
      Number of Data Packets Recieved............ 0
      Number of Data Rx Packets Dropped.......... 0
      Number of Data Bytes Recieved.............. 0
      Number of Data Rx Bytes Dropped............ 0
      Number of Realtime Packets Recieved........ 0
      Number of Realtime Rx Packets Dropped...... 0
      Number of Realtime Bytes Recieved.......... 0
      Number of Realtime Rx Bytes Dropped........ 0
      Number of Data Packets Sent................ 0
      Number of Data Tx Packets Dropped.......... 0
      Number of Data Bytes Sent.................. 0
      Number of Data Tx Bytes Dropped............ 0
      Number of Realtime Packets Sent............ 0
      Number of Realtime Tx Packets Dropped...... 0
      Number of Realtime Bytes Sent.............. 0
      Number of Realtime Tx Bytes Dropped........ 0
Nearby AP Statistics:
      arg-col-primA-ap0(slot 0)
        antenna0: 91 secs ago.................... -77 dBm
        antenna1: 91 secs ago.................... -77 dBm
      arg-col-primA-ap1(slot 0)
--More-- or (q)uit
        antenna0: 86 secs ago.................... -82 dBm
        antenna1: 86 secs ago.................... -79 dBm
        antenna0: 60 secs ago.................... -81 dBm
        antenna1: 60 secs ago.................... -82 dBm
        antenna0: 85 secs ago.................... -89 dBm
        antenna1: 85 secs ago.................... -92 dBm
        antenna0: 50 secs ago.................... -94 dBm
        antenna1: 50 secs ago.................... -94 dBm
        antenna0: 3 secs ago..................... -80 dBm
        antenna1: 3 secs ago..................... -86 dBm
      arg-col-primA-ap2(slot 0)
        antenna0: 73 secs ago.................... -96 dBm
        antenna1: 73 secs ago.................... -97 dBm
        antenna0: 86 secs ago.................... -86 dBm
        antenna1: 86 secs ago.................... -90 dBm
        antenna0: 24 secs ago.................... -87 dBm
        antenna1: 24 secs ago.................... -86 dBm
--More-- or (q)uit
        antenna0: 69 secs ago.................... -94 dBm
        antenna1: 69 secs ago.................... -94 dBm
        antenna0: 36 secs ago.................... -61 dBm
        antenna1: 36 secs ago.................... -69 dBm
        antenna0: 37 secs ago.................... -84 dBm
        antenna1: 37 secs ago.................... -79 dBm
        antenna0: 148 secs ago................... -91 dBm
        antenna1: 148 secs ago................... -86 dBm
      arg-col-secu-ap08(slot 0)
        antenna0: 83 secs ago.................... -96 dBm
        antenna1: 83 secs ago.................... -97 dBm
        antenna0: 84 secs ago.................... -90 dBm
        antenna1: 84 secs ago.................... -88 dBm
      arg-col-primB-ap1(slot 0)
        antenna0: 269 secs ago................... -95 dBm
        antenna1: 269 secs ago................... -94 dBm
        antenna0: 82 secs ago.................... -77 dBm
--More-- or (q)uit
        antenna1: 82 secs ago.................... -80 dBm
        antenna0: 78 secs ago.................... -90 dBm
        antenna1: 78 secs ago.................... -87 dBm
        antenna0: 82 secs ago.................... -82 dBm
        antenna1: 82 secs ago.................... -81 dBm
        antenna0: 31 secs ago.................... -78 dBm
        antenna1: 31 secs ago.................... -84 dBm
        antenna0: 145 secs ago................... -90 dBm
        antenna1: 145 secs ago................... -84 dBm
        antenna0: 58 secs ago.................... -96 dBm
        antenna1: 58 secs ago.................... -97 dBm
DNS Server details:
      DNS server IP ............................. 207.83.200.201
      DNS server IP ............................. 200.38.100.210
Assisted Roaming Prediction List details:
Client Dhcp Required:     False
VIP Purple
If you disabled the low data rates & TKIP after my first response, do the same performance testing & measure the throughput you are getting.
Have you used iperf application for performance testing ? If so I would suggest to do iperf testing using wireless client at branch & one of the server at your main office. See the upload & download speed you will get.
I will give you some references later if you are not familiar with this process
Rasika
*** Pls rate all useful responses ****
Thanks a lot! If fact the vWLC is in the cloud with no local APs, only 2 remote locations (schools) with 76 APs in total. All VPNend. I did the changes however I will be able to run the test onsite on Monday. I did use the iperf in the past however I might need to get back to you. As of now we were simply testing the download speed with speedtest.net.
Remi
Hi Remi,
Hi Remi,
I know that the thread is very old, but would like to ask if you solved this and how?
Because seems that I am facing the very similar issue like you.
Thanks a lot
Tomas
Hi Tomas,
Hi Tomas,
No problem. It's been a while since I had this problem but I think what I did was to disable low data rates no both 802.11a/n and 802.11b/g/n radios - everything below 12Mbps and played with the roaming. I had quite high desinty of the APs over quite small area and therefore the minimum RSSI I set to -50dBm. This way the clients did not stay connected to an AP that was far away but roamed to the closest AP. This was mainly causing the low bandwidth.
Hope this helps and let me know how it went on your side.
Remi
Please check if the version is it the version issue.
In Release 7.3, the bandwidth  contract feature was enhanced so that rate limits  can be defined on  both upstream and downstream traffic. Rate limits could be  defined per  SSID and/or specified as a maximum rate limit for all clients. These   rate limits could be individually configured. This feature was supported  on the  following APs: AP1140, AP1040, AP3500, AP3600, AP1250, and  AP1260. In centrally  switched WLANs, the downstream traffic is rate  limited by the controller and the  upstream is rate limited by the APs.  In local switched WLANs, both upstream and  downstream are traffic are  rate limited by the APs.
In Release 7.4, this feature is also supported on  AP1600.
For more information please go through the link below.
http://www.cisco.com/en/US/docs/wireless/controller/release/notes/crn74.html
Hello Basant,
Thanks for the info. The vWLC version I am running on is 7.4.110.0 (the AssureWare). I will look at the rate limits at the SSID level tomorrow morning.
Remi
Hall of Fame Super Silver
Re: Very Low Bandwidth on AIR-CAP1602 FlexConnect Local and vWLC
I would test using iperf/jperf like Rasika mentioned. Test within your network and I would also run a traceroute to see what path local or centrally switching is taking out to the internet.
When you say very low bandwidth, how is the internal traffic... File transfers from site to site, etc?
Thanks, Scott *****Help out other by using the rating system and marking answered questions as "Answered"*****
731
