(VERY URGENT !!!) Cisco 1262 AP Antenna Cable length Extension
Hi Team
Kindly assist me in providing an extension for the below antennas cable length for project related requirements with the AP 1262.
AIR-ANT2506
2.4 GHz, 5.2 dBi Mast Mount Omni Ant w/RP-TNC Connector
AIR-ANT5160V-R
5GHz 6dBi Omni Antenna w/RP-TNC connector
Pls consider this request as highly urgent. Looking forward to your replies.
UKV
  • Getting Started with Wireless
Hall of Fame Super Silver
Re: (VERY URGENT !!!) Cisco 1262 AP Antenna Cable length Extensi
Cable extensions depends on how long of an extension you need. You need to calculate the total EIRP required minus your cable loss, connector loss, and TX power. Either you will use LMR 400 or LMR 600, but many time it will be custom cable for the connectors required.
Thanks, Scott *****Help out other by using the rating system and marking answered questions as "Answered"*****
Hall of Fame Super Gold
What are you trying to do or accomplish?
The longer the external antenna cable the LOWER signal strength.
Not trying to be rude here or something, but alot of the people who help by posting solutions are doing this during their free times.   So this means that if you want to do something quickly then you need to raise a Cisco TAC case.
It's all about the length of the cable and type .. The cable specs will call ours your cable loss ..
__________________________________________________________________________________________ "Satisfaction does not come from knowing the solution, it comes from knowing why." - Rosalind Franklin ___________________________________________________________
Here is a good online calculator if you decide you want to extend your antenna cable.
http://www.timesmicrowave.com/cgi-bin/calculate.pl
Scott Fella
Sent from my iPhone
161
