Community Member
Virtual WLAN Controller and AIR-AP1240 & 1130 serie
Is it possibile to convert AIR-AP1240 and 1130 serie from standalone to controlled for VIRTUAL WLAN Controller?
1 REPLY
VIP Purple
Yes, it is possible. First
Yes, it is possible. First you have to convert your AP from Standalone mode to Lightweight. You have to get the recovery images to do this conversion given below & follow the link for the procedure.
c1130-rcvk9w8-tar.124-25e.JAP.tar
c1240-rcvk9w8-tar.124-25e.JAP.tar
http://mrncciew.com/2012/10/20/lightweight-to-autonomous-conversion/
Then you should be able to register these AP to your vWLC. Further to that you have to change the AP mode from Local to FlexConnect in order to use these in vWLC environment. Here is some vWLC deployment guide which may help you
http://www.cisco.com/c/en/us/support/docs/wireless/virtual-wireless-controller/113677-virtual-wlan-dg-00.html
Also refer this document for the WLC software versions required for different model of AP.
http://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
Rasika
**** Pls rate all useful responses ***
74
