vlan in the wireless lan
Hi to all,
if i create 2 vlan and i configure 2 ssid one for each vlan, this two vlan are created only for the wireless interface? Or i need to reconfigure all the lan equipment for this 2 vlan?
If i configure 2 vlan and the relative ssid i need two bvi interface configured with two different ip-address or i can use only one bvi with one ip address?
Thanks and best regards,
Carlo S.
1 REPLY
Re: vlan in the wireless lan
The vlans are not only created for the wireless interface but also for the ethernet. Then the ethernet interface has to be connected with a switch that supports vlans. After that, it's up to you to do whatever you want with the vlans you created.
You don't need 2 BVI IPs. You only need one to be able to manage the AP
130
