WAP312 - Captive Portal does not work with VLAN tagged LAN
Hi there,
I need some help, maybe someone have already had the same or similar issue.
I have bought a Cisco WAP321 recently to build up a WLAN with captive Portal functionality.
Here MY Setup:
  • LAN
  1. Untagged VLAN: disabled
  2. Management VLAN ID: 50
  3. Static IP: 192.168.50.201
  • Wireless
    • VAP No. 0:
      • VLAN ID = 50
      • SSID Name = MGMT
    • VAP No. 1:
      • VLAN ID = 20
      • SSID Name = Guest
  • Captive Portal
    • VAP 1 = Captive Portal instance wiz_cp_inst1 (created via the Setup)
Problem:
When connecting a Laptop (MacBook) to the Guest WLAN an ip address will be assigned by the DHCP Server correctly, but opening a webpage fails, the browser starts to load but stucks after a short while.
When changing the config to:
  • LAN
  1. Untagged VLAN: enabled
  2. Management VLAN ID: 1
  • Wireless
    • VAP No. 0:
      • VLAN ID = 50
      • SSID Name = MGMT
    • VAP No. 1:
      • VLAN ID = 1
      • SSID Name = Guest
  • Captive Portal
Result:
Once connected to the guest WLAN an ip address will be assigned by the DHCP Server correctly AND the browser is being opened automatically with the captive Portal Login page.
Does anybody know what's wrong here?
Hope someone can support me here soon as i have to install the WLAN soon.
Many thanks in advance
Dirk
Hi,I have the same problem
I have the same problem with new WAP371, firmware 1.0.1.5.
Captive portal works only on vap-s on vlan1 that is untagged.
OH NOOOOOOO, i just bought a
OH NOOOOOOO, i just bought a WAP371 yesterday. FUCK.
Hey d.martincic, i think i
Hey d.martincic,
i think i found a solution here. :-)
You have to associate the cp instance to VAP0 (usually your management WLAN) also.
See attachment, without association CaptivePortal didn't work for Guest VLAN, but it starts working after adding it.
Stupid config, but Cisco might have another logic.
Hope that will solve your issue also.
Bye
Dirk
Dirk, Thank You,this strange
Dirk, Thank You,
this strange solution works also for me.
Bye,
Danilo
255
