Community Member
WAP4400N will not accept firmware upgrade
We just received a WAP4400N, new in box. I'm able to get it working fine; however, it refuses to accept the downloaded upgrade image WAP4400N_R1.2.14-ETSI.img -- it claims it's not a valid image format.
I've re-downloaded this 3 times, it's no-brainer. I wonder if the image on cisco.com is corrupted, or if there is another problem.
Anyone else see this?
Thanks.
Hall of Fame Super Gold
Re: WAP4400N will not accept firmware upgrade
Have you gone through this document?
Upgrading the firmware of the WAP4400N
http://www.cisco.com/en/US/products/ps10047/products_qanda_item09186a0080a36a24.shtml
Community Member
Yes, I did read this - it's a no-brainer and these units are fairly easy to update.
It does not work. I've tried it 4 times.
For what it's worth, the unit itself doesn't really have much in terms of version information; however, the information on the back shows:
3839A-WAP4400N
Manufactured 10/2008
Community Member
BTW, when this unit is hooked up to our switch, we see these types of errors:
%Apr 11 21:56:59:544 2000 4200G MSTP/3/FWDWHILERR:- 1 -GigabitEthernet1/0/6 Rcv: FwdDelay Info is wrong
I'm beginning to suspect the unit is defective.
Community Member
Nevermind. I've sent the unit back -- we're getting a Netgear device instead.
The purpose of this WAP did not warrant a higher-end Cisco WAP. It's just for testing.
901
