WAP4410N requires pin w Vista? CIsco doc on fix doesn't help.
New purchase of a WAP4410N, it comes configured out of the box for no wireless security.  First experience with a Cisco Business product.
According to Cisco doc https://www.myciscocommunity.com/servlet/JiveServlet/download/20021-7048/Connecting%20Vista%20to%20WPS.doc, this is a known issue where a pin is required, and the doc instructs you to use the "Run as Unsecured" option.  In my case, it doesnt work and since all of my wireless systems run Vista, I cannot use the router, and the seller wont take it back (I'm past their 30 day return policy)
On my new router, I dont get that far: when I try to blow past the Enter Pin screen, I get a "Cannot connect to Network" response from Vista, no connection (and I dont have any wireless security configured at all - totally disabled).  Where to next?  Will firmware fix this?  There is no pin anywhere on the unit or box to use to get past this.
1456
