WC 5500 - HA
Thierry95
Hi all.
I have a little question concerning WC 5500 cisco HA.
I configured HA with 2 WC 5500.
i have one active controller and one standby.
But, i can't manage my cluster with GUI.Only by cli.
Have you any idea ?
Thanks.
Thierry.
Scott Fella
You should be able to access the GUI of the primary.
-Scott
Abhishek Abhishek
Hello Thierry,
As per your query i can suggest you the following solution-
An optional redundant power supply that helps to ensure maximum availability
Hope this will help you.
Viten Patel
As Scott mentioned you should be able to manage the active controller using the GUI.
Both controllers still have a unique self signed cert so if you management ip is tied to the backup's cert and if you cached the cert on the browser you will get an error.
Try clearing the browser cache and/ or try another browser
