WCS and Autonomous AP Cisco 1242
I Would like connect few Aps Cisco 1242 on WCS with snmpv3 in the same security WLCs. I have a probleme to add manually AP1242 on this WCS
For AP Cisco 1242 snmp v3 don't existe by browser web then ,I added follow line in CLI command :
Cisco1242(config)#:snmp-server user snmpuser remote v3 encrypted auth sha **************** priv des56 ********************
***** = password
For WCS, I used Add Autonomous Acces Points:
Please, what do think ?  I suppose it is something which miss.
Thank you for your help.
Laurent.
Hall of Fame Super Silver
You have telnet enabled on the ap?  That is all I can think that might be the issue.
-Scott
Hi Scott,
I checked, the telnet is enabled on AP.
I dont't have problem to connect AP in SNMPV2 but I would like to connect this AP in SNMP V3 for security.
Thank.
Laurent
Re: WCS and Autonomous AP Cisco 1242
Well if you have v3 setup on the AP and that is working correctly, I don't know why it's not working then on WCS. I have not tried v3.
Scott Fella
Sent from my iPhone
-Scott
Hi Scott,
I found my problem:   missing engine ID to validate the connection.
It work now.....
Thank you.
Laurent
725
