WCS Maps - tracing the walls with heavy and light walls question
I'm wondering if I anyone else has experienced a misalignment of your walls after you have drawn them on your floor plan in WCS.  I have rather large floor plans that have seven buildings all connected together.  Some buildings are taller than others, and some don't have Wi-Fi in them.  For that reason, I only format the portion of the floor plan that has wireless in it.
Recently we have been adding more access points to other parts of the building, so I go back and trace more walls where I am installing the service.  I notice that other portions of the building's traces have shifted off the original floor plan's walls.
Anyone else seeing this, and if so, do you have a fix?
Thanks in advance.
Hall of Fame Super Red
Hi there,
What WCS version are you running?
Cheers!
Rob
Re: WCS Maps - tracing the walls with heavy and light walls ques
7.0.164.0
Hi there,
It sounds like this bug
CSCtk74855 - Map Editor walls misaligned after image is rescaled
Description
Symptom:
When a floor image has already been edited with Map Editor, then the image is scaled, upon returning
to Map Editor, the walls will be in different places, requiring them to be redrawn.
Conditions:
This happens only when an edited wall is rescaled.
Workaround:
Scale the floor before making edits with Map Editor.
Details
1st Found-in:                          (1)
7.0(164.0)
Status:
Terminated
Last Modified:
Oct 02,2011
Product:
Cisco Wireless Control System
Platform:
Dependent
Severity:
3 - moderate
Customer Reported:                          (2)
Cheers!
Rob
Thanks for doing my digging, Rob!
Note to self: Scale drawing first.
409
