Weird Problem with Cisco Aironet AP1242G-E-K9 - Previous authentication no longer valid
Hey all,
hope you could help me
Got a warehouse with 3 AccessPoints of type mentioned above.
Before I changed them to Cisco 1242 there were Cisco A1210 on duty.
New APs got the same settings but now I got the follwing
*Jan  3 02:50:00.026: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station xxxx.xxxx.xxxx Reason: Previous authentication no longer valid
*Jan  3 02:50:00.033: %DOT11-4-MAXRETRIES: Packet to client xxxx.xxxx.xxxx reached max retries, removing the client
The clients need to have a durable connection, errors will affect disconnecting of the clients (they have time-crit applications).
Here the configfiles of the 3 Access Points (Just dot11 int):
AP1
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 2 mode ciphers aes-ccm
encryption vlan 1 key 1 size 128bit 7 ****** transmit-key
encryption vlan 1 mode ciphers wep128
ssid pLBF11b
ssid pLBF11bSEC
antenna transmit right-a
antenna receive right-a
mbssid
power local 8
channel 2412
station-role root
rts threshold 2312
no dot11 extension aironet
world-mode dot11d country-code DE outdoor
no cdp enable
AP2
no ip address
no ip route-cache
encryption vlan 1 key 1 size 128bit 7 ***** transmit-key
ssid pLBF11b
ssid pLBF11bSEC
mbssid
channel 2437
station-role root
rts threshold 2312
no cdp enable
AP3
no ip address
no ip route-cache
ssid pLBF11b
ssid pLBF11bSEC
mbssid
power local 2
power client 10
channel 2462
station-role root
rts threshold 2312
no cdp enable
As you can see I disabled the aironet extensions (found this in this forum) and all APs uses non overlapping channels (1,6,11).
Any ideas?
Thanks in advance for helping me.
Chris
  • Getting Started with Wireless
Everyone's tags (3)
I am assuming that you are connecting the antennas!!
the error means that the CLient is not abke to grab the wireless signal properly.. either the client is getting very weak signal strength coz of which the client is getting disconnected..
The power levels configured are very low..
2 and 8 and default on each APs..
Please issue the below command and see if this helps
en
conf t
int dot11 0
power local max
power client max
end
Surendra
Hey Surendra,
thank your for you suggested solution.
Did this on all 3 Access Points, but still got connection problems:
Reply of 172.16.42.134: Bytes=32 Time=528ms TTL=60
Reply of 172.16.42.134: Bytes=32 Time=338ms TTL=60
Reply of 172.16.42.134: Bytes=32 Time=46ms TTL=60
timeout.
timeout.
timeout.
timeout.
timeout.
timeout.
timeout.
timeout.
Reply of 172.16.42.134: Bytes=32 Time=33ms TTL=60
*Feb  9 12:50:39.792: Client xxxx.xxxx.xxxx failed: reached maximum retries
*Feb  9 12:50:39.792: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 000b.6b1f.9e94 Reason: Previous authentication no longer valid
Chris
Re: Weird Problem with Cisco Aironet AP1242G-E-K9 - Previous aut
Ok, did some changes in the dot11 config and updated the firmware.
This message disappears after fw update.
Still my clients have problems with connectivity losses (2sec-5sec). Is there any debug I can make to gather information 'bout their problems?
All channels have a load of 5-7%.
Thanks in advance for your answers.
Chris
//EDIT:
Forgot the new dot11 cfg
no ip address
no ip route-cache
ssid pLBF11b
ssid pLBF11bSEC
mbssid
channel 2412
station-role root
rts threshold 64
no cdp enable
Hey all,
switched back to the old AIR-AP1231G-E-K9 with c1200-k9w7-mx.122-13.JA4 firmware.
No problems occurs with this ones.
What's the best way to figure out, what this access points doin' properly and the new ones don't.
Thanks in advance for your help.
Chris
3009
