what IOS-based AP for AIR-ANT2410Y-R (Bridge between two buildings)
We need to connect two buildings with wlan. Due to the environment we will use AIR-ANT2410Y-R Yagi Antenna. What actual AP (IOS-based) supports this antenna. Is the AIR-SAP2602... the right choice? And how to configure the AP with only one antenna-cable (the 2602 has 4 connectors)
Moin Ilyas
Level 4
Level 4
System Requirements for AIR-ANT2410Y-R
This antenna is designed for use with Cisco Aironet access points and bridges but can be used with any 2.4-GHz Cisco Aironet radio device that uses an RP-TNC connector.
Hello
you used only one antenna (AIR-ANT2419Y-R) for AP?
You can use Cisco Aironet access points.
Please refer the link below for more information.
http://www.cisco.com/c/en/us/products/collateral/wireless/aironet-antennas-accessories/product_data_sheet09186a008008883b.pdf
sobhardw
Cisco Aironet 1200 Series and Aironet 1300 Series Access Points supports AIR-ANT2410Y-R Yagi Antenna.
http://www.cisco.com/c/en/us/td/docs/wireless/antenna/installation/guide/ant2410Y.html#wp49163
