While upgrade to LWAP error : AP Radios not supported.
Hello Experts,
i am using upgrade tool and LWAP image c1100-rcvk9w8-tar.123-11JX1.tar.but still i am not able to  upgrade to LWAP.
when i check detail log in upgrade tool its shows the AP Radios  not supported.can somebody help me in this regard. Thank you in  anticipation..
Below are the logs of the AP while doing LWAP upgrade
*Mar  1 00:00:05.712: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to r
eset
*Mar  1 00:00:05.713: %DOT11-2-NO_FIRMWARE: Interface Dot11Radio0, no radio firm
ware file (flash:/5101.img) was found
*Mar  1 00:00:05.714: %DOT11-2-NO_FIRMWARE: Interface Dot11Radio0, no radio firm
*Mar  1 00:00:05.715: %DOT11-2-RESET_RADIO: Interface Dot11Radio0, Radio firmwar
e file not found, Trying hardware reset on radio
*Mar  1 00:00:12.706: %DOT11-2-NO_FIRMWARE: Interface Dot11Radio0, no radio firm
*Mar  1 00:00:12.707: %DOT11-2-NO_FIRMWARE: Interface Dot11Radio0, no radio firm
*Mar  1 00:00:13.008: %DOT11-3-POWERS_INVALID: Interface Dot11Radio0, no valid p
ower levels available
*Mar  1 00:00:13.008: %DOT11-2-RADIO_FAILED: Interface Dot11Radio0, failed - fir
mware file not found
-Traceback= 18F68 405868 3FDFB0 4072E0 129B34 129BDC 116F0 11904 1357B0
*Mar  1 00:00:15.059: %SYS-6-LOGGERSTART: Logger process started
*Mar  1 00:00:15.061: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to
up
*Mar  1 00:00:16.061: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthern
et0, changed state to up
*Mar  1 00:00:16.617: %SYS-5-CONFIG_I: Configured from memory by console
*Mar  1 00:00:16.617: %SYS-5-RESTART: System restarted --
Cisco IOS Software, C1100 Software (C1100-K9W7-M), Version 12.3(8)JA2, RELEASE S
OFTWARE (fc1)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Tue 30-May-06 17:41 by pwade
*Mar  1 00:00:16.618: %SNMP-5-COLDSTART: SNMP agent on host RH-W-D36-AP1121G is
undergoing a cold start
*Mar  1 00:00:16.642: Writing radio coredump to 'flash:/r0.rcore'
*Mar  1 00:00:17.334: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, chan
ged state to up
*Mar  1 00:00:31.891: Writing radio coredump to 'flash:/r0.rcore'
*Mar  1 00:00:37.051: Interface Dot11Radio0: not starting because stop-on-failur
e set
*Mar  1 00:00:37.058: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to do
wn
*Mar  1 00:00:38.058: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio
0, changed state to down
RH-W-D36-AP1121G#
Sh ver : and sh flash
RH-W-D36-AP1121G#sh fla
RH-W-D36-AP1121G#sh flash:
Directory of flash:/
    2  -rwx     3650405  Mar 15 1993 18:04:33 +00:00  c1100-k9w7-mx.123-8.JA2
    3  -rwx         272  Mar 01 2002 00:00:16 +00:00  env_vars
    7  -rwx      525184  Mar 01 2002 00:00:37 +00:00  r0.rcore
    5  -rwx          79  Mar 01 2002 02:12:52 +00:00  private-config
    4  -rwx        2072  Mar 01 2002 02:12:52 +00:00  private-multiple-fs
    6  -rwx        6626  Mar 01 2002 02:12:51 +00:00  config.txt
    8  drwx         128  Mar 01 2002 02:31:37 +00:00  c1100-rcvk9w8-mx
7741440 bytes total (1694208 bytes free)
RH-W-D36-AP1121G#sh ver
OFTWARE (fc1)
ROM: Bootstrap program is C1100 boot loader
BOOTLDR: C1100 Boot Loader (C1100-BOOT-M) Version 12.2(8)JA, EARLY DEPLOYMENT RE
LEASE SOFTWARE (fc1)
RH-W-D36-AP1121G uptime is 23 minutes
System returned to ROM by reload
System image file is "flash:/c1100-k9w7-mx.123-8.JA2"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-AP1121G-E-K9     (PowerPCElvis) processor (revision A0) with 15038K/13
36K bytes of memory.
Processor board ID FOC08301UAW
PowerPCElvis CPU at 197Mhz, revision number 0x0950
Last reset from reload
1 FastEthernet interface
1 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:11:93:F1:0E:BA
Part Number                          : 73-7886-07
PCA Assembly Number                  : 800-21481-07
PCA Revision Number                  : A0
PCB Serial Number                    : FOC08301UAW
Top Assembly Part Number             : 800-22053-04
Top Assembly Serial Number           : FHK0835V1J0
Top Revision Number                  : A0
Product/Model Number                 : AIR-AP1121G-E-K9
Configuration register is 0xF
RH-W-D36-AP1121G#
Also i reformated the iamge K9w7 again as i was only able login through CMD and while explorer still this error coming-
RH-W-D36-AP1121G Home Page
Cisco Systems
Accessing Cisco AIR-AP1121G-E-K9 "RH-W-D36-AP1121G"
Web Console - Manage the ap through the  web interface.
Show diagnostic log - display the diagnostic  log.
Monitor the router - HTML access to the  command line interface at level 0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15
Show tech-support - display  information commonly needed by tech support.
Extended Ping - Send extended ping commands.
Help resources
  1. CCO at www.cisco.com - Cisco Connection  Online, including the Technical Assistance Center (TAC).
  2. tac@cisco.com - e-mail the TAC.
  3. 1-800-553-2447 or +1-408-526-7209 - phone the TAC.
  4. cs-html@cisco.com - e-mail the HTML  interface development group.
Appreciate your quick response and suggestions.
Re: While upgrade to LWAP error : AP Radios not supported.
Ap is broken,thats why radio interfaces are down.
Pavan kumar P
Hello ,
What are you refering by word Broken AP(1121series ) how do i confirm it is broken.
when i access it from CLI it looks completely fine m but when i do GUI access it shows the above GUI screen.
Can you Please help me to how to to check it is damaged.
Appreicate all your respnse.
KA.
Hello Guys,
Any one can Please update me on this issue.
KA.
708
