Why am I not getting DHCP addresses?
This is driving me nuts...either getting 0.0.0.0 or 169 addresses....if I wireshark on local comp dhcp requests are going on but getting no replies to them.
If I make the AP a dhcp server the unit gets an address and can ping the AP but not the gateway.
Other APs are set up similarly with no issue. I just want a basic 1 SSID config...what am I doing wrong?
Current configuration : 1968 bytes
! Last configuration change at 02:22:39 UTC Mon Mar 1 1993 by Cisco
version 15.2
no service pad
service password-encryption
hostname ap
logging rate-limit console 9
enable secret 5 $1$Mkq1$HdLwkEV0Hn/GwnQDYJ4Md.
no aaa new-model
no ip routing
no ip cef
no ip domain lookup
ip domain name bigstonetherapies.local
dot11 syslog
dot11 ssid BigTest
   authentication open
   authentication key-management wpa
   guest-mode
   wpa-psk ascii 7 071B245F5A584B5643
dot11 guest
username Cisco password 7 0802455D0A16
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
shutdown
encryption mode ciphers aes-ccm
ssid BigStone
antenna gain 0
stbc
beamform ofdm
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio1
no ip address
no ip route-cache
ssid BigStone
antenna gain 0
peakdetect
dfs band 3 block
stbc
beamform ofdm
channel dfs
station-role root
bridge-group 1
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
ip address 10.0.0.40 255.255.255.0
no ip route-cache
ipv6 address dhcp
ipv6 address autoconfig
ipv6 enable
ip forward-protocol nd
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
login local
transport input all
end
ap(config)#
1 ACCEPTED SOLUTION
why is your radio0 interface on shutdown?? try enabling it, create subinterface Dot11radio0.1, Dot11radio1.1, and gigabitethernet0.1 with dot1q encryption 1 native, bridge-group 1. Your problem is related to native vlan mismatch on both sides i think.
Where is your DHCP server configured?
VIP Purple
Re: Why am I not getting DHCP addresses?
Your AP does not have default-gateway configured. In 15.2 IP routing is enabled by default & you can configure ip route 0.0.0.0 0.0.0.0 instead of "ip default-gateway" command.
Below is the extract from given release notes
http://www.cisco.com/en/US/docs/wireless/access_point/ios/release/notes/15.2_2_JB.html#wp147667
IP Routing Enabled By Default
IP routing is enabled by default in 15.2(2)JB. This default configuration will render ip default-gateway statements inoperable. The work around is to disable ip routing globally (config t, no ip routing), or configure a default route instead of a default-gateway (e.g. config t, ip route 0.0.0.0 0.0.0.0 ).
Also in the above AP configuration defined SSID (BigTest) & configured SSID (BigStone) under interface is different.
Rasika
**** Pls rate all useful responses ****
Alright so now IP routing is enabled and I have an IP route statement added but still same result.
My DHCP server is 10.0.0.21
version 15.2
no service pad
hostname ap
no aaa new-model
ip cef
no ip domain lookup
dot11 syslog
dot11 ssid BigStone
   authentication open
   guest-mode
dot11 guest
bridge irb
no ip address
shutdown
ssid BigStone
antenna gain 0
stbc
beamform ofdm
station-role root
bridge-group 1
no ip address
ssid BigStone
antenna gain 0
peakdetect
dfs band 3 block
stbc
beamform ofdm
channel dfs
station-role root
bridge-group 1
no ip address
duplex auto
speed auto
bridge-group 1
interface BVI1
ipv6 address dhcp
ipv6 enable
ip http server
ip route 0.0.0.0 0.0.0.0 10.0.0.1
bridge 1 route ip
line con 0
line vty 0 4
login local
transport input all
end
VIP Purple
Hi Anthony,
Are you able to ping 10.0.0.1 & 10.0.0.21 IP from the AP ?
Post the switchport interface configuration  where this AP connect to.
Rasika
Rasik,
I can ping everything from the AP. The switch is an ESW 520 managed from a GUI, no switchports are tagged for vlans.
Hall of Fame Super Silver
Connect a laptop to a port on that switch and see if the laptop gets a dhcp address.  Verify that the dhcp scope is enabled on the dhcp server.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
dhcp is working on the network. If I reset the AP to factory defaults it pulls an address from the server.
Try using WPAv2 since your using AES-CCM.  Make sure that the clients are using WPA2-Personal (WPA2/AES)
config t
dot11 ssid BigStone
authentication key-management wpa version 2
For testing, set the BVI to dhcp and try to associate.
Scott
-Scott
I truly appreciate all of the ideas, I thought Tat had it but still having the same issue after making the changes. Anything further anyone can suggest?  Here is current config.
Building configuration...
Current configuration : 2543 bytes
! Last configuration change at 04:10:47 UTC Fri Oct 25 2013 by Cisco
! NVRAM config last updated at 21:12:47 UTC Sun Oct 27 2013 by Cisco
version 15.2
no service pad
hostname ap
enable secret 5 $1$pUrT$qP2QZ8BbjtmJE.vwoQ7FX/
no aaa new-model
no ip routing
no ip cef
dot11 syslog
dot11 ssid BigStone
   vlan 1
   authentication open
   guest-mode
dot11 guest
username Cisco password 7 01300F175804
bridge irb
no ip address
no ip route-cache
encryption vlan 1 mode ciphers aes-ccm
broadcast-key vlan 1 change 30
ssid BigStone
antenna gain 0
stbc
beamform ofdm
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
no ip address
no ip route-cache
ssid BigStone
antenna gain 0
peakdetect
dfs band 3 block
stbc
beamform ofdm
channel dfs
station-role root
interface Dot11Radio1.1
no ip route-cache
bridge-group 1
no ip address
no ip route-cache
duplex auto
speed auto
interface GigabitEthernet0.1
no ip route-cache
bridge-group 1
interface BVI1
no ip route-cache
ipv6 address dhcp
ipv6 enable
ip default-gateway 10.0.0.1
ip http server
bridge 1 route ip
line con 0
line vty 0 4
login local
transport input all
end
Was port security on the switch. Thanks everybody for your replies.
Enable Dot11radio11 and it will work.
291
