12-13-2011 12:05 AM - edited 07-03-2021 09:13 PM
Hello Experts,
I have a Cisco 1140 AP, and using express setup I have cnofigured a IP address to it. This AP is connected to our public network and is configured with a public ip address. We want the guest users to connect to Wifi and gain access to Internet.
While the users connect to Wifi, I find their laptops getting IP address in series 169.x.x.x due to which they are unable to get to internet.
Can somebody guide to what all configuration required so that laptops would get ip address?
Arvind
12-13-2011 04:57 AM
Hi there can you post your ap config and a brief comment on your design.
Also, what DHCP server are you using for your clients and do you have IP helpers set up ?
12-13-2011 10:19 AM
you did not configure your access on public IP address first u terminate your link on router create dhcp server on the router for your client to get the Ip address.
Posted by WebUser Anshul Rohilla
12-14-2011 01:50 AM
Hello George,
I do not have any DHCP server, I want the AP to allocate IP addresses to wifi clients.
Anshul,
Is there any way the AP distribute the IP addresses? I want to have the AP act as an DHCP server and allocate IP address of wifi clients.
If this is not possible in this AP model 1142N, any other Cisco AP model available, which can act as DHCP server?
My requirement basically is:
The AP should allocate IP in the range 192.168.x.x and I would connect the AP to the public network. The wifi clients should be able to get to Internet.
Please suggest any other model in Cisco which should meet my requirement.
Arvind
12-14-2011 04:28 AM
The AP can act as a dhcp server so long as you have configured the scope in the subnet the BVI is in. If the clients are going to get an address not in the BVI subnet, then you would need to put an ip helper on the gateway pouring at the APs address
