Wifi Traffic flow from PC to DHCP server
 Hi Everyone,
Below is Wireless setup.
WAP-------------------Switch -----------------WLC
As per above WAP has single connection to switch and WLC has 2 connections to switch.
WLC has default gateway which is ASA.
Switch also has default gateway which is also same ASA.
ASA is configured as DHCP server.
So when now wi fi user connects to SSID configured in WLC the traffic will flow
from PC  to WAP -----Switch------------WLC-----from WLC  it goes to default gateway which is ASA to get the IP?
MAhesh
1 ACCEPTED SOLUTION
Hi,Data traffic from wireless
Data traffic from wireless client will be encapsulated into CAPWAP tunnel and then will be forwarded to WLC.Then from your WLC to Default Gateway.
Take a look here:
http://www.cisco.com/c/en/us/td/docs/solutions/Enterprise/Mobility/emob73dg/emob73/ch2_Arch.html
Hope it helps,
Regards.
1 REPLY
Take a look here:
Hope it helps,
Regards.
140
