wildcard cert on WLC 4404 running 5.2
Hi all
I have a WLC with a cert on at the moment, it runs out in a few weeks.
I want to replace the current cert with a wildcard cert.
Will this be OK ?
is it a cas
VIP Purple
Re: wildcard cert on WLC 4404 running 5.2
As per my exp.: yes it is supported.
However, it seems there is still a problem with wildcards certificates if they are chained :
Check this links:
http://netboyers.wordpress.com/2012/03/06/wildcard-certs-for-wlc/
Third part cert:
http://www.cisco.com/c/en/us/support/docs/wireless/4400-series-wireless-lan-controllers/109597-csr-chained-certificates-wlc-00.html
Dont forget to rate helpful posts
Hall of Fame Super Gold
Carl,
Get out of firmware 5.X.  This is the "Miley Cyrus" of WLC.
Don't stay with the "miley cyrus" code
Or else, you'll wind up like wearing a face like this ... Priceless.
http://static.businessinsider.com/image/521ad37c69bedd7f7c00004f/image.jpg
Hall of Fame Super Silver
Wildcard certificates does work, but I have never tried it on a WLC running that old of a code.  You will need the cert and the private key as you will need to create a certificate for the WLC.  You can't just upload a wildcard certificate.
Upgrade to 7.0.240.0 if possible... Don't stay with the "miley cyrus" code:)
Scott
*****Help out other by using the rating system and marking answered questions as "Answered"*****
-Scott
118
