02-09-2012 05:31 AM - edited 07-03-2021 09:33 PM
First, I know the 4400 has been EOS. I am planning on replacing this with a new controller next year as part of a larger project. In the meantime, the certificate we have setup on our guest network is due to expire soon.
I am pretty familiar with how to get a new certificate setup, but was wondering if anyone has had any experience at using a "wildcard" type certificate, instead of the standard webserver style cert? (http://www.digicert.com/wildcard-ssl-certificates.htm)
Its my understanding that a wildcard certificate can be used for any type of server, but the server needs to support it.
Thanks.
02-09-2012 05:41 AM
As far as I know, the wlc do not support wildcard certificates.
Scott Fella
Sent from my iPhone
02-09-2012 05:44 AM
All my recent install using a 3rd party certificate has been with installing a chained certificate.
Here is a doc that shows you how to combine a chained certificate and install it on a wlc.
http://www.cisco.com/en/US/products/ps6366/products_configuration_example09186a0080a77592.shtml
02-09-2012 05:44 AM
I was afraid of that. Thanks for the comments. Hopefully, I can escilate the plan to replace it.
02-09-2012 05:46 AM
No problem... Maybe one day it will be supported:)
02-09-2012 07:13 AM
To be thorough, I opened a TAC Case, and was told that we could, in fact, use a Wildcard certificate. The link I was sent is the same one you linked.
I have not tried this, nor do I have a lab unit to test on.
02-09-2012 07:16 AM
That is the same link I sent you.. Well let me know if it works:)
Scott Fella
Sent from my iPhone
