wireless AP - autonomous
hi! I'm trying to configure an autonomous AP to be used. The native vlan of the network is 1 and the testwifi vlan is vlan 20. In the switch port where the AP is connected to trunk and dot1q encap is on by default + native vlan 1. The dhcp svr is in the native vlan segment with an ip helper address on the vlan 20 segment. Will the configuration below in the AP work? Is there anything that i missed out? Thanks.
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers aes-ccm tkip
encryption vlan 20 mode ciphers aes-ccm tkip
broadcast-key change 300
broadcast-key vlan 20 change 300
ssid testwifi
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.20
encapsulation dot1Q 20
no ip route-cache
bridge-group 20
bridge-group 20 subscriber-loop-control
bridge-group 20 block-unknown-source
no bridge-group 10 source-learning
no bridge-group 10 unicast-flooding
bridge-group 20 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
no dfs band block
channel dfs
station-role root
bridge-group 1
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
interface FastEthernet0.1
no ip route-cache
bridge-group 1
interface FastEthernet0.20
no ip route-cache
bridge-group 20
no bridge-group 20 source-learning
bridge-group 10 spanning-disabled
interface BVI1
ip address 10.10.1.1 255.255.255.0
no ip route-cache
bridge 1 route ip
1 ACCEPTED SOLUTION
Re: wireless AP - autonomous
the only that looks off to me is the radio11.20 is shutdown, but a quick no shut will fix that. And I wouldn't use the DFS channels, should be ok for a home deployment, but I'd do a carrier busy test and find the least congested channel and hard set the AP to use it.
Otherwise from what I see that should work. Just remember to call out the VLAN under the said as well
One last thing I would do is prune any unneeded VLAN from the trunk
Steve
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
1 REPLY
Steve
308
