Wireless AP - Not able to ping default gateway from wireless client
I hv configued AP 1310 in Root bridge with client mode. BVI interface has been configured with static ip and the default gateway has been configured
Wireless client successfully get's the ip address from DHCP server on network through bridge but not able to ping the gateway or any other ip on the network.
Wireless client is successfully able to ping the bridge ip once it get ip address from dhcp server.
At the same time from bridge I am able to ping gateway and all the other ip successfully.
below is the configuration :
clock summer-time R recurring
ip subnet-zero
ip domain name xxxxxx
dot11 activity-timeout unknown default 15
dot11 activity-timeout client default 15
dot11 activity-timeout repeater default 15
dot11 activity-timeout workgroup-bridge default 15
dot11 activity-timeout bridge default 15
dot11 ssid AAAAAAAA
authentication open
infrastructure-ssid
dot11 network-map
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption key 1 size 128bit 7 BBBBBBBBBBBBBBBBB transmit-key
encryption mode wep mandatory
ssid AAAAAAAA
speed basic-12.0 18.0 24.0 36.0 48.0 54.0
power local 50
station-role root bridge wireless-clients
rts threshold 4000
concatenation
no dot11 extension aironet
infrastructure-client
bridge-group 1
bridge-group 1 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
full-duplex
bridge-group 1
interface BVI1
ip address X.X.X.X Y.Y.Y.Y
no ip route-cache
ip default-gateway X.X.X.X
no ip http server
ip http authentication aaa
ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
1 REPLY
Re: Wireless AP - Not able to ping default gateway from wireless
Does anybody had above such issue. Is there any config change to be done on the bridge side ??
Any help will be appreciated.
310
