Community Member
Wireless AP will not join WLC 2112
First post and first question...I have a WLC 2112 running 7.0.98.0 and have 6 ap's. For some reason, none of the AP's are joining or associating with the WLC. I can see them on the switch and they are getting the correct IP so that isn't an issue. I've also tried to add them by MAC address under AP policies. Just looking for a little insight or direction. I've done this on about 40 other WLC but first time this has happened and not sure where to go.
Thanks to all in advance for any and all insight
1 REPLY
Hall of Fame Super Gold
Re: Wireless AP will not join WLC 2112
1.  Switch to AP:  Access Port
2.  Switch to WLC:  Trunk port
3.  Is the time on the WLC set correctly?
4.  Is your AP running the correct version of IOS?  It should have the "RCV" filename.
368
