Wireless Auth errors
I am trying to setup leap authentication on a 1100 AP, with local radius.
Getting the following debug errors:
*Mar  2 10:23:05.311: dot11_auth_dot1x_run_rfsm: Executing Action(CLIENT_WAIT,TIMEOUT) for 0023.6c85.32cd
*Mar  2 10:23:05.311: dot11_auth_dot1x_send_client_fail: Authentication failed for 0023.6c85.32cd
*Mar  2 10:23:05.311: %DOT11-7-AUTH_FAILED: Station 0023.6c85.32cd Authentication failed
*Mar  2 10:23:10.592: AAA/BIND(00000070): Bind i/f
*Mar  2 10:23:10.592: dot11_auth_dot1x_start: in the dot11_auth_dot1x_start
*Mar  2 10:23:10.592: dot11_auth_dot1x_send_id_req_to_client: Sending identity request to 0023.6c85.32cd
*Mar  2 10:23:10.592: dot11_auth_dot1x_send_id_req_to_client: Client 0023.6c85.32cd timer started for 30 se
Any ideas what could be wrong with my config:
aaa new-model
aaa group server radius rad_eap
server 172.16.1.35 auth-port 1812 acct-port 1813
aaa authentication login eap_methods group rad_eap
aaa session-id common
dot11 syslog
dot11 ssid XXX
   authentication open eap eap_methods
   authentication network-eap eap_methods
   guest-mode
interface Dot11Radio0
no ip address
no ip route-cache
encryption key 1 size 40bit 7 873B0AA56FCA transmit-key
encryption mode wep mandatory
broadcast-key change 300
ssid XXX
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
channel 2437
station-role root
rts threshold 2312
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
ip address 172.16.1.35 255.255.255.0
no ip route-cache
radius-server local
  nas 172.16.1.35 key 7 14001305020B297D727E
  user xxxx nthash 7 0027435225792D535F796A6B2A3852444A59285D78097D7B6A177B325144545374
radius-server attribute 32 include-in-access-req format %h
radius-server host 172.16.1.35 auth-port 1812 acct-port 1813 key 7 120E04191C040F527C7D
radius-server vsa send accounting
bridge 1 route ip
Re: Wireless Auth errors
I can see that we are using the internal radius server... Whats the authentication that we are using??
i mean whats the EAP flavour??
Surendra
If you are not using any EAP authentication, then remove the below commands..
and issue just "authentication open"
then try connecting the wireless using the WEP key that you have configured.
Surendra
307
