Wireless Authentication EAP
I recently removed some configuration from an AP but added it back in.  Now when the clients connect to it they are unable to authenticate.  On the ACS server I get this message, "Invalid message authenticator in EAP request".  I have confirmed that the keys on the AP and on the ACS server are correct.  What else I could be missing here?
aaa new-model
aaa group server radius rad_pmip
aaa group server radius dummy
aaa group server radius rad_infrastructure
server 10.206.110.225 auth-port 1645 acct-port 1646
server 10.202.110.225 auth-port 1645 acct-port 1646
aaa group server radius rad_client
aaa group server radius rad_admin
aaa group server radius rad_eap
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server tacacs+ tac_admin
aaa authentication login default group tac_admin local
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authentication login method_rad_infrastructure group rad_infrastructure
aaa authentication login method_rad_client group rad_client
aaa authentication enable default group tac_admin enable
aaa authorization console
aaa authorization exec default group tac_admin local
aaa authorization network default group tac_admin if-authenticated
aaa accounting send stop-record authentication failure
aaa accounting exec default start-stop group tac_admin
aaa accounting commands 1 default start-stop group tac_admin
aaa accounting commands 15 default start-stop group tac_admin
aaa accounting network acct_methods start-stop group rad_acct
aaa accounting connection default start-stop group tac_admin
aaa accounting system default start-stop group tac_admin
aaa session-id common
clock timezone CST -6
clock summer-time CST recurring
ip telnet source-interface BVI1
ip tftp source-interface BVI1
ip name-server 10.200.10.5
ip ssh source-interface BVI1
ip ssh logging events
ip ssh version 2
dot11 ssid InfManagement
   vlan 1
   authentication open eap eap_methods
   authentication network-eap eap_methods
   authentication key-management wpa
   accounting acct_methods
dot11 ssid CORP-Phones
   vlan 20
dot11 ssid CORP-WiFi
   vlan 40
dot11 ssid dartyyz.ca
   vlan 1000
   authentication open
power inline negotiation prestandard source
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 1 mode ciphers tkip
encryption vlan 20 mode ciphers tkip
encryption vlan 40 mode ciphers tkip
encryption vlan 1000 mode wep mandatory
ssid InfManagement
ssid CORP-Phones
ssid CORP-WIFI
ssid dartyyz.ca
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.20
encapsulation dot1Q 20
no ip route-cache
bridge-group 20
bridge-group 20 subscriber-loop-control
bridge-group 20 block-unknown-source
no bridge-group 20 source-learning
no bridge-group 20 unicast-flooding
bridge-group 20 spanning-disabled
interface Dot11Radio0.40
encapsulation dot1Q 40
no ip route-cache
bridge-group 40
bridge-group 40 subscriber-loop-control
bridge-group 40 block-unknown-source
no bridge-group 40 source-learning
no bridge-group 40 unicast-flooding
bridge-group 40 spanning-disabled
interface Dot11Radio0.1000
encapsulation dot1Q 1000
no ip route-cache
bridge-group 100
bridge-group 100 subscriber-loop-control
bridge-group 100 block-unknown-source
no bridge-group 100 source-learning
no bridge-group 100 unicast-flooding
bridge-group 100 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
ssid InfManagement
ssid CORP-Phones
ssid CORP-WiFi
ssid dartyyz.ca
dfs band 3 block
channel dfs
station-role root
interface Dot11Radio1.1
no ip route-cache
bridge-group 1
interface Dot11Radio1.20
no ip route-cache
bridge-group 20
interface Dot11Radio1.40
no ip route-cache
bridge-group 40
interface Dot11Radio1.1000
no ip route-cache
bridge-group 100
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
hold-queue 160 in
interface FastEthernet0.1
no ip route-cache
bridge-group 1
interface FastEthernet0.20
no ip route-cache
bridge-group 20
interface FastEthernet0.40
no ip route-cache
bridge-group 40
interface FastEthernet0.1000
no ip route-cache
bridge-group 100
interface BVI1
ip address 10.139.32.41 255.255.255.128
no ip route-cache
ip default-gateway 10.139.32.1
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
logging trap debugging
logging 10.3.10.88
logging 10.202.106.95
access-list 19 permit 10.3.10.88
access-list 19 permit 10.202.0.20
access-list 19 permit 10.202.110.0 0.0.0.255
access-list 19 permit 10.200.40.0 0.0.0.255
access-list 19 deny   any log
snmp-server trap-source BVI1
tacacs-server host 10.206.110.225 key
tacacs-server host 10.202.110.225 key
tacacs-server directed-request
radius-server attribute 32 include-in-access-req format %h
radius-server host 10.206.110.225 auth-port 1645 acct-port 1646 key
radius-server host 10.202.110.225 auth-port 1645 acct-port 1646 key
radius-server timeout 10
radius-server vsa send accounting
bridge 1 route ip
  • Getting Started with Wireless
"Invalid message authenticator in EAP request" message means:-
wrong radius key or dont use short key.. like cisco .. use some bigger password and then try..
Well weird tried different keys and nothing worked.  I changed the key back to what it was originally and it works now.  For some reason even though I deleted everything from the ACS server it was caching the settings some where.
217
