Wireless Authentication LDAP
Hello all,
I am trying to gain a better grasp of authenticating users in a wireless environment.  I plan to deploy a 5500 series WLC that authenticates users against a LDAP server. I am having trouble understanding how to deploy wireless access to all users in the LDAP directory. I want users to user there standard login credentials to gain access to the wireless network. from my understanding you must create a certificate for each user and install it on there wireless device prior to them accessing the network for them to use the wireless network. is there away that a user can just use their credentials to log on?
  • Getting Started with Wireless
1 ACCEPTED SOLUTION
Hello Luke,
If you are going to use 802.1x with LDAP, It all depends on your EAP type that you want your clients to use.
Only EAP-TLS needs certificates on both WLC and clients. EAP-FAST needs PACS on the clients. PEAP needs a certificate on the AAA server.
If you are going to use Layer 3 authentication (web authentication) then there is no need to use certificates on clients.
Here is a config example of Local EAP with LDAP on WLC:
http://www.cisco.com/en/US/products/ps6366/products_configuration_example09186a008093f1b9.shtml
Here is a config example of Web-auth with LDAP on WLC:
http://www.cisco.com/en/US/products/ps6366/products_configuration_example09186a0080a03e09.shtml
Amjad
Rating useful replies is more useful than saying "Thank you"
Hello Luke,
Amjad
Thankyou Amjad,
i am a little clearer on the topic know.
I will be using eap-tls know and use a radius server with NPS autoenroll to send out certifcates.
Thanks Luke.
Wish you all the best with your deployment
Cheers,
Amjad
839
