Wireless bridge association issue
I'm trying to troubleshoot a wireless link using Aironet 1400.
All the configuration is very simple, using ssid, open authentication, no encryption. And everything is default.
I'm getting this error in the root bridge:
*Oct  6 20:43:45.261: %DOT11-6-ASSOC: Interface Dot11Radio0, Station Non-root 0012.431f.ce75 Reassociated KEY_MGMT[NONE]
*Oct  6 20:43:45.282: %DOT11-4-MAXRETRIES: Packet to client 0012.431f.ce75 reached max retries, removing the client
*Oct  6 20:43:45.283: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0012.431f.ce75 Reason: Previous authentication no longer valid
Any suggestion about the issue?
P.S. configuration:
dot11 ssid Testing123
   authentication open
   infrastructure-ssid
interface Dot11Radio0
no ip address
no ip route-cache
ssid Testing123
station-role root bridge
no dot11 extension aironet
bridge-group 1
bridge-group 1 spanning-disabled
Thanks you
Everyone's tags (2)
1 REPLY
Re: Wireless bridge association issue
Hi Omar,
The message means that there is communication problem between the two bridges due to most probably one of two reasons:
1- Signal strength to low
2- Interference on channel
After having verfified, that the bridges have been correctly installed and poinint to each other, try to make them communicate on one of these 3 channels:
1, 6 or 11
If that doesn't help, share a bit the installation details, are they currently in the LAB? if not, what is the distance between them, how are they installed, is there line of sight ?
Do the two bridges ever succed to establish a connection for at least couple of minutes? if yes, please get a "show dot11 asso all" from the root bridge, let's have a look at the signal strength.
Serge
593
