Wireless Bridge Solution
I am looking for a wireless Bridge Solution the distance between 2 buildings is 200 Metre approx and the height of the buildings are 24 metres. The desired bandwidth is 11 Mbps and above.
Please help me in finalizing the solution. I am looking for a cheap solution other than 1300, 1400 or 1500 solution.
Regards..
Hall of Fame Super Silver
Re: Wireless Bridge Solution
You can always use a 1242 in bridge mode with external antennas. You will need a NEMA heated/cooled enclosure for the ap unless that will be mounted indoors, lightning arrestor and LMR cable to extend the antenna if required and antenna mounting hardware. But with most systems, you will need line of site, so hopefully you have this. Antenna wise, you can go with a yagi at both ends.
http://www.cisco.com/en/US/prod/collateral/wireless/ps5678/ps6521/prod_qas0900aecd8031c8dc.html
http://www.cisco.com/en/US/prod/collateral/wireless/ps7183/ps469/product_data_sheet09186a008008883b.html
-Scott
Thanks for your reply.
It seems that if I will use 1310 with integrated antenna the price will be less than 1242. Is NEMA enclosure required for 1310 bridge. Secondly if I had to mount it in outdoor environment what all accecories I will require.
Thanks and regards,
Pulkit Sharma
244
