wireless client bridge mode -- ?? model?
I need an AP that can run in client bridge mode. By that I mean a device that can be connected to a PC via the ethernet cable and provide wireless access because these older devices don't have wireless network cards?
I looked at the WAP321 but it just uses a wizard. I need a device with IOS so that the PSK keys can be encrypted when viewing. I need to have the config backed up and the PSK can't be in clear text.
Any information on what model to choose is very much appreciated.
Thank you,
Re: wireless client bridge mode -- ?? model?
Take a look at the 1131 or 1242 of G rates are ok. Both can run on universal WGB mode.
Steve
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
Yup 1130 is an inexpensive enterprise way to go. Give this a read
http://www.cisco.com/en/US/products/ps6087/products_tech_note09186a0080b90500.shtml
__________________________________________________________________________________________ "Satisfaction does not come from knowing the solution, it comes from knowing why." - Rosalind Franklin ___________________________________________________________
Thanks guys! Do you know the command to encrypt the psk? I can't have it in clear text. All i see is the base command which still displays the psk in clear text:
wpa-psk ascii sample_key
Thank you,
Hall of Fame Super Silver
It is hashed if you do a show run from the CLI.
-Scott
Bronze
You can use any of the Cisco IOS units like the 1230-1250-1140-1240, etc and use the option of WGB that will allow the AP in this mode to connect to an existing AP and then you can connect on the lan port a end device or a switch.
Check on the FAQ for WGB.
http://www.cisco.com/en/US/products/hw/wireless/ps441/products_qanda_item09186a0080094644.shtml
WGB configuration example.
http://www.cisco.com/en/US/products/hw/wireless/ps430/products_configuration_example09186a00805b9b87.shtml
1935
