Wireless Client DHCP issue - MESH AP (1552 E)
5508 WLC = 7.4.100
1552 E AP
I have a range of APs running in FlexConnect mode that have no issue connecting to all 3 SSIDS
I have recently added MESH APs which connect to the controller without issue.
I can only connect to 2 of 3 SSIDs through the MESH AP. The 3rd SSID displays connected and  status associated but no IP address is passed to the wireless client.
I have tried ethernet bridging and assinging VLAN ID of the Native VLAN ID and adding configured VLAN IDs.
Advice and assistance would be appreciated.
Hall of Fame Super Silver
With mesh, you do not need to
With mesh, you do not need to enable ethernet bridging at all.  All the traffic should tunnel back to the WLC as if the mesh ap was a local mode ap.  Make sure that if you are using AP Groups that the WLAN to vlan mappings are correct.  The other thing is that you should be on v7.4.121.0 and also make sure you have uploaded the latest FUS 1.9.0.0 onto the WLC for stability.  I have mesh networks on both v7.4.121.0 and v7.6.120.0, working just fine.
Scott
-Scott
agreed that ap group wlan
agreed that ap group wlan/interface mappings is the first thing to check.
pending what you find out there, a client debug when a client is failing to get an ip address when connected to the 3rd ssid on the mesh ap will be the next step
Thanks I have done the client
Thanks I have done the client debug and it seems to point to a layer 2 issue where when i compare a client connecting through a flexconnect AP the EAP Type = EAP-TLS
Yet with a MESH client EAP Type = 0
hmm, that's odd.  as a point
hmm, that's odd.  as a point of reference, is it possible to test the same with another eap type, maybe Peap?
Are the flex ap's doing local authentication for the wlan of interest?
255
