Wireless client disconnection issue
Hi All,
we using AP AIR-SAP-1602E-N-K9 running in standalone mode, were we are finding the intermittent client disconnection issue with an specific laptop.
Dell latitude : Nic : Intel<R> Dual Band Wireless-AC 7260
We are finding issue with only with this laptop.any suggestion to find the cause.
Channa
VIP Purple
Hi Channa,This Intel driver
Hi Channa,
This Intel NIC is famous for issues. Make sure you have latest drivers (17.0.5.8) on it & check. Here are some reference links from intel/otehr community
1. http://community.arubanetworks.com/t5/Unified-Wired-Wireless-Access/Intel-7260-ac-Driver-17-0-5-8-Bookmark-this-one/td-p/182228
2. https://communities.intel.com/message/229486#229486
3. https://communities.intel.com/thread/44899
4. https://communities.intel.com/thread/48125
I am also having similar issues with this NIC & waiting for a proper fix.
Pls do not forget to rate our responses if it is useful.
Rasika
Hi Rasika,Thanks for your
Hi Rasika,
Thanks for your responses.
Is there any workaround for the problem.
Channa
VIP Purple
Hi Channa,Go for the latest
Hi Channa,
Go for the latest driver version 17.0.5.8 & check it again. Intermittent connectivity issue should be fixed in that version. You can download it from here.
https://downloadcenter.intel.com/SearchResult.aspx?lang=&ProductID=3714&ProdId=3714
You have to test & let us know how good this is :)
Rasika
*** Pls rate all useful responses ****
Normally the only solution of
Normally the only solution of that kind of problem is to upgrade your drivers or use fresh windows installation if the system is causing problem ,like malware or any unknown threat can create that kind of problem.
The above will solve your issue, lastly check in your AP is it set to  MIX mode i.e b/g as your laptop is also dual  band, and set channel assignment to automatic.
885
